  • Replies 79
i agree with why they are doing it..... iv seen some stupid sh*t involving lowlux's at 80kmh doing "dumpies" producing a heap of sparks out the arse....
however it wont happen, and if it does, nothing like how they r saying now.....as sydkid said.... there are so many variables its not funny.
5cm Geeze thats crazy lets hope this doesnt get enforced you could get done for picking up a couple of mates, lucky i got fairly stiff coilovers i suppose at least they don't sag so much, but seriously this is rediculous just another stupid law.
Don't get me wrong i agree 100% with stopping those ediots that cut there springs on their fully sick VL but this is a bit over the top.
For those that wish to get coil overs but can't till after the deadline - just get an engineers report created for them (even though you dont actually have them) before the legislation is effective. I am sure someone who knows someone can help you out :P
And then again all of this is a bunch of hot air - we are not supposed to have sports air filters on our cars but I can assure you that almost every skyline has one. As long as your car is not rediculously low and blows sparks over every bump and you dont drive like hoon I am sure you won't have a problem.
these people really need to get a life... like really.. how many serious or even non serious accidents are there because of vehicle height?? most accidents are caused by speed and having 5 mates in the car.
Just to clear it up, height adjustable coil overs aren't legal, never have been. Unless the car comes with them standard from the manufacturer. So producing a dated receipt for a set of height adjustable coil overs on an R32/33/34 won't help you one little bit.
Cheers
Gary
glad I dont own a skyline now :/
Don't get too smug, I went on a MX-5 cruise once, a cop pulled 2 of the MX-5s over and issued defects but let me go on my way :domokun:
Granted, they where driving like flamin' mongrels and I was just cruising lol
i recon if you are over 100mm off the ground you should be right without an engineers certificate. If your car has been lifted or lowered by more than 50mm I think you need an engineers certificate and give it to the RTA to be legal. Having a receipt for coilovers from pedders will mean jack shit. I dont think its possible for sports cars and family cars to be more than 50mm lower in ride height and still be over 100mm clear off the ground. And radical modification you do to your ride you should really get an engineers cert as if you crash you could void your insurance and the typical engineers cert only cost $500.
On engineers i hear they are clamping down on them very soon as up here in Newcastle a pejero just recently got caught by the RTA with an engineers cert allowing 44'' tires.
so just to clear this up, as i dont get when the car has to be engineered, i def wont have to money to lower my line before aug 1st, so after that, wen i go to pedders or somewhere and have them lower it, will they engineer it or will i have to drive around to a engineers place after it. wat happens if i get pulled over between then and there, " hey im just goin to the place now" " yea right heres ya fine, have a good one"
I thought this law was for lift kits?
Anyway to the point I dont know why everyone cares. You all have intake systems im sure, most deff run some form of boost controller or you even run a boost gauge into cabin. All defects and this is just another.
A defect is a defect and its still a f**kload of paper work.
hmm I skimmed through the link...
it's all well and good we need to fill these forms out but they don't specify the costs that will be involved for an 'adjustment of records'. knowing the RTA it's going to be a rort
this is all BS my springs I ordered aren't going to drop my car more than 1 inch and still be height legal, so Im not concerned about it being legal, what is pissing me off is the extra stuffing around & costs I will have to cop now
it says though any AUVIS station should be able to do the inspection, which means theoretically if a motor dealer's service dept was an auvis i could just take it there?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
