i got a 33 turbo on my 32 with rb20det, external gate, screamer, fmic and exhaust,
running 1 bar atm and it seems to be fine, any less and its a slug, i was thinking about changing the springs to run 17ps (1.15bar)
ive run this much with my avcr and it seems fine, any experiences with this much boost?
  • Replies 56
Its not going to matter what engine its on...the turbo will fail at 17psi and a few hard stabs at the throttle
What a load of crap.
how do you figure that.
the turbo is now on a car that has 500cc less capacity and 0.5:1 less compression.
to produce 17 psi of air flow on the RB20 it spins at a different speed and creates different amount of heat than it would on an RB25.
having said that, I didn't go past 14psi on my RB20 with R33 turbo.
having now said that, since a hiflow from hypergear is now about $800, I wouldn't be too fussed if it popped.
ext gate on a stock turbo - i could think of better things to waste money on :)
But either way, 15-16psi is the absolute limit and the turbo wont last forever.
It's still ceramic, its still going to suffer from heat... which is the killer.
Then you add to the fact you are now spinning the shaft ever faster than RB25 owners (who's turbos generally die 12psi+)... its all asking for a turbo death.
Heat + excessive shaft speed = failure
thanks so much GTST , finally someone who knows what they on about,
i been drifting on 1 bar for a while now and i know its not at max efficiency yet cause when i run 1.1bar i can noticeably feel the difference mid slide, it smokes up a lot more, so i just wanted to see who else has been running 1.15 bar and are ok? to give me a piece of mind, ppl said 1 bar was too much on my rb20 with r33 turbo but it seems absolutley fine
lol its not a waste of money , i got it for next to nothing and it was cheap to weld on :) my car is a slider so gate was a must for me hahahaha
plus when it blows its got an appt with GCG :)
but im not ready for that atm hahahahaha so just doing a bit of homework b4 changing my gate springs tonight :) thanks for your concernthough~! :)
hahaha youre awesome zebra, good to see you like hardstyle so i cant say your 100% a top bloke lolol
try to add something constructive into your posts man im after some info not your jibberish unbacked opinions...
theres aLWAYS one of you tools in every thread.. lurking around lolol
i reckon you can run more boost through a 33 turbs on a rb20 compared to a 25 zebra so im gonna have to disagree with you there buddy :)
Can you explain this for us Nismoid?
Boost is just a measure of the resistance of the head, for the shaft to spin quicker on an RB20 there must be less resistance...
I'm no RB20 expert, but what you're saying is the RB20 head flows better than the RB25 head?
Just keep smashing boost in to you find the limit of the 25 turbo , then fit another n try again
Nice pick of your 33 gts-t there mate :)
Hey mate,
This is a bit of a trial and error excercise for you. As stated above you can run more boost through it cos its an RB20, not as much stress on it as a 25.
1.15 will be fine I reckon. Put a few heat protecting mods like heat wrap or a turbo bag around it to protect it more and i reckon you'll be able to run 1.25-1.3 at drift meets.
PM me if you have any more questions
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
