Hi peoples. We're back from our two months holiday in Europe. We drove just over 13,000kms across six countries and had an absolute ball. I can't tell you how much I LOVE the Autobahns in Germany. No Toll, no bumps or potholes, just perfectly smooth tarmac and no speed limits on most of them. We found out that our brand new 1.6 turbo diesel Peugeot redlined at 195km/h in 5th gear and wouldn't go any faster :D And also that it's a kind of a special feeling when you overtake a cop car at 165km/h and they don't even look at you. Oh and when ze krazy germanz overtake you when you're cruising on 170km/h and they accelerate away from you like you were doing 60.
When we flew out of Paris, it was 35 degrees there so it's been a bit of a shock coming back to sunny Canberra. This place was one of the highlights. Can anyone guess where this pic was taken? :iluvff:
https://www.sau.com.au/forums/topic/279392-hi-were-back/
Sure did. I still can't get the grin off my face. That place is so addictive that you just want to keep going back for more laps, and each time you become more and more confident and faster as you learn the track. Next time we're definately hiring a race car.
These are some of the machines we shared the track with:
https://www.sau.com.au/forums/topic/279392-hi-were-back/#findComment-4720692
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
