hey guys, how do i go about getting more steering angle for my r33 drift car? cheers
im in the middle of doing the same mod to mine, ive started with with just the tie rod spacers, surprised how much ive gained, i had to grind my steering stops heaps to maximise the lock, it comes close to overcentreing..so im thinking of cutting down my steering knuckles/rewelding the pickup point and maybe repositioning the rack forwards.
Edited by drf76
That depends...
What has it got at the moment?
If it is 100% stock, then there is a few tricks and bits, if you've done some mods, then this could get more technical.
If it's stock, buy a pair of rack-end spacers, and install them. Ask any of the sponsors selling them for someone's before and after pics. I swear by them, best money and time I've spent. Easy U turns in an average residential street, without wheelspin :P
If it is just a drift car, try running a bit of toe-out, as this will effectively increase the steering angle of the inside wheel (one carrying the majority of the force during opposite lock) but sacrifices outer wheel grip to do so. You may notice a tiny bit longer delay in turn-in from a straight-line grip approach, as the outer wheel takes longer to actually point into the corner.
Don't do this on a street car. It WILL kill your tyres, and result in bad road handling, due to the outside wheel having barely any grip.
Beyond this, you may need to look into modifications of the suspension components, the rule here is not to let the tie rods form a straight line (or go beyond!!) with the part of the knuckle they join to. If that occurs, you will not be able to return the wheels, as they will most likely "cam-over" and be stuck into position at full lock = you WILL hit something.
Edited by nato_wp
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
