Hi,
I have a R34 GTT with the triptronic, i bought a Power FC, i installed it, started up, did the idle learn
and went for a ride...
The car stays at some gear(3rd i think) and that's it, no triptronic and not good mixture...
What can i do about this? Except manual conversion...
Akis
Edited by Akis
https://www.sau.com.au/forums/topic/279503-r34-gtt-triptronic/
It's a shame you didn't do some research before you bought it. Haven't seen you on the forums before so I'll assume you didn't know what almost everybody else does, PFC is for manual only. You need to contact Toshi, do a search.
I did searched it... but i saw that the only thing that it could be a problem where the harsh gear changes..
Today i bought a manual conversion so i guess everything wil be solved.. :D
Thanks for answering..
Akis.
Harsh..more like *no* gearchanges ;) When you take out the ECU, you remove the control unit for the transmission, that's why it stays in 3rd. If you had a 25GT, it would have run just fine though, bloody Nissan.
A conversion will sort that out though ;)
Harsh..more like *no* gearchanges :) When you take out the ECU, you remove the control unit for the transmission, that's why it stays in 3rd. If you had a 25GT, it would have run just fine though, bloody Nissan.
A conversion will sort that out though :)
Is the auto trans control on a non-turbo R34 separate?
Yep, it's only the GTt that has the intergrated TCM.ECM the N/A has the TCM seperated, so when you take out the ECU it still has gearshift capability.
So how I "understand" it the non-turbo auto would be better suited to aftermarket ECUs - if that's what you intend on doing...
  • 3 months later...
It is absolutely Plug&Play. :(
Hi Akis,
I know the thread is a little old but hopefully you may know an answer, I know of some series 1 98 skylines that have had a manual conversion using the auto loom are having problems with the plug and play PowerFC. infact its not as plug and play as we thought, problems with the TCS, Engine light and Aircon compressor. Any idea's why we'd be having such issues?
Cheers
TCS and engine lighl and also Slip are on because the Power FC doesn't co-operate with the TCS so check engine is on. That's what happened with mine. I do not need the TCS.. i think it is better to have the control by yourself.. ;)
About the aircon compressor i havent noticed anything..
For the engine light i think there is a solution..
  • 7 months later...
hi akis i would appreciate any help you can give, am desperate. looking for the part # for an r34 rb25de neo
transmission ecu and also if i can get a picture of the connector to that ecu, thanks in advance.
Augustin.
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
