Hi,
I have a R34 GTT with the triptronic, i bought a Power FC, i installed it, started up, did the idle learn
and went for a ride...
The car stays at some gear(3rd i think) and that's it, no triptronic and not good mixture...
What can i do about this? Except manual conversion...
Akis
Edited by Akis
https://www.sau.com.au/forums/topic/279503-r34-gtt-triptronic/
It's a shame you didn't do some research before you bought it. Haven't seen you on the forums before so I'll assume you didn't know what almost everybody else does, PFC is for manual only. You need to contact Toshi, do a search.
I did searched it... but i saw that the only thing that it could be a problem where the harsh gear changes..
Today i bought a manual conversion so i guess everything wil be solved.. :D
Thanks for answering..
Akis.
Harsh..more like *no* gearchanges ;) When you take out the ECU, you remove the control unit for the transmission, that's why it stays in 3rd. If you had a 25GT, it would have run just fine though, bloody Nissan.
A conversion will sort that out though ;)
Harsh..more like *no* gearchanges :) When you take out the ECU, you remove the control unit for the transmission, that's why it stays in 3rd. If you had a 25GT, it would have run just fine though, bloody Nissan.
A conversion will sort that out though :)
Is the auto trans control on a non-turbo R34 separate?
Yep, it's only the GTt that has the intergrated TCM.ECM the N/A has the TCM seperated, so when you take out the ECU it still has gearshift capability.
So how I "understand" it the non-turbo auto would be better suited to aftermarket ECUs - if that's what you intend on doing...
  • 3 months later...
It is absolutely Plug&Play. :(
Hi Akis,
I know the thread is a little old but hopefully you may know an answer, I know of some series 1 98 skylines that have had a manual conversion using the auto loom are having problems with the plug and play PowerFC. infact its not as plug and play as we thought, problems with the TCS, Engine light and Aircon compressor. Any idea's why we'd be having such issues?
Cheers
TCS and engine lighl and also Slip are on because the Power FC doesn't co-operate with the TCS so check engine is on. That's what happened with mine. I do not need the TCS.. i think it is better to have the control by yourself.. ;)
About the aircon compressor i havent noticed anything..
For the engine light i think there is a solution..
  • 7 months later...
hi akis i would appreciate any help you can give, am desperate. looking for the part # for an r34 rb25de neo
transmission ecu and also if i can get a picture of the connector to that ecu, thanks in advance.
Augustin.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
