Hey All
Im just chasing some help with the final install of my stereo.... I have hooked up front and back speakers to the head deck and now just need help with amp and sub as i clearly have no idea what im doing... =]
Pic 1 + 2 are the amp and Pic 3 is the back of the head unit... about the RCA plugs on head unit it says "SW FRONT"
I have two sets of RCA cords from the wiring kit that i havent used yet so i was just chasing clear instructions on how to connect my amp to the head unit and the amp to the sub.... As im stuggling with where EXACTLY to wire the sub to on the amp......
Any help is greatly apreciated
https://www.sau.com.au/forums/topic/279511-intall-help-please/
Hey dude
First things first. Based on the pics posted, you have a four channel amp. However, your HU only has one set of pre-outs. So to connect your amp up to your HU, you will need to get yourself some Y-connectors/splitters. What these do is turn a two channel HU into a four channel HU (in a sense really anyway).
To get you started follow these simple steps:
1. connect the red and whites RCA plugs to the back of your HU.
2. connect one Y connector to the red plug and the other to the white plug.
3. plug the Y connectors into the amp. Matching white with white and red with red.
Congrats, you have now given the amp a sound signal. Now to connect the remote wire to turn the amp on.
1. grab some 4mm wire from your local auto shop
2. on the back of your HU, there should be the remote wire for the amp. It should be blue in colour. If you're still unsure about which wire is which, the wiring diagram should be on the top (or bottom) of the HU. That will tell you which wire it is.
3. join this wire to the wire you bought from the shop and run it to the location of your amp.
4. connect it up to your amp.
Congrats, you have given your amp a switch. Now when you trun your HU on, the amp will turn on.
Connecting your sub now depends on how many subs you have and whether or not you want to run other speakers off the amp. The best way that I would suggest would be to bridge channels 3/4 to power your sub and use channels 1 and 2 to power your front speakers. You can use the on board crossover to tune the speakers and sub to whichever frequencies you want.
Give that a go and see how it all ends up. Doing it that way, should work out to be the simplest and most effective method.
If you have any dramas, post up and let us all know.
Good luck
Tony
I have only a few arguments with the above post
Leave your fronts hooked up how they are, to the headunit.
Run one set of rcas to the boot and plug one end into the back of your h/u and plug the other end into the "front" input on the amp, then for hooking your sub to the amp, you will notice that under channels 1 and 2 it says bridged and indicates which two terminals you use for "bridged mode" these are the two you want to hook your sub into.
The only time id concider using those Y splitters, is if you had a 4 channel amp and 2 subs, using the front channel for one sub and the rear channel for the other sub. Using Y splitters and running front speakers AND a sub off the same output of the headunit is never gonna sound good.
Yes, that is one other set up you could use in this scenario. Both setups are good and will both sound equally as good. It does all mainly depend on the type of amp he is using and the types of sub/speakers. Again, based on the pictures the OP has posted, the amp being used has a built in crossover. This would mean that if he did use 3/4 for the sub and 1 & 2 for the front speakers, they could all be tuned separately. I have had this set up in my own cars many times before and they have sounded great for a basic set up.
Each to their own I guess
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
