Seems this is common on RB26 However makes more sense on the lower hose as it's cooler and will promote flow And correction to my previous post about it being the RB26 thermostat, we can see that it's not in this photo -
By TurboTapin · Posted
It's an 80$ part on Amayama. Just replace it and be done with it. -
It is in the top hose and not the bottom, that way it come straight out and into radiator rather then back into the engine
By fletch rb30 · Posted
In a previous incarnation I ran it round the back and into the thermostat inlet teed into the heater return. It worked fine, but when I turned it off, I could hear it boiling and slugging etc. I figured it would be good to try and get it towards the radiator and let convection cool it until it was the dame temp as everything else. I thought rb26 had a nipple on the top hose fitting where both the turbo water returns went. I have seen people delete that with a rd28 outlet and run the turbo outlet straight to the radiator top tank. -
By Prof_Finesser · Posted
I talked to WS they said I could either have a charge cable connecting the alt to the starter or the alt to the fuse box which I have it. The two wires shown are one from the alt to starter and the other is the ring terminal from the harness that says starter power. Theres no power wire shown. I asked him he said there should be in power wire from the battery, the ring terminal from the harness, and then finally the signal spade connector I have it set up like that currently. I'm just gonna test all the stuff Duncan said and will get back to yall.
