Ive cleaned the connections with contact cleaner and the coils are splitfires with sparkies gapped to .8mm. Could the little earth wire for the ignitor module cause the a bad miss on WOT?
The car is a rb25det r32.
ok, spent a bit of time on it this weekend
new plugs .8 gap, valley cleaned out.
coils have been siliconed, contact cleaned all plugs and ignitor module
Cleaned afm/plug and tps/plug
Its a terrible miss but ONLY on WOT. The car idles fine, and drives fine..its only when i floor it gets around 4000rpm does the car farts and pops, dumps some fuel smoke etc. It doesn't seem like a coilpack miss or the sort, more like a failing sensor of some sort?
What else should i try?
r32 rb25
Hiflow 16 psi
Supporting mods
The car was running fine, but then a slight missed occurred up high, so i changed over to coils with unknown condition, made the problem way worse. Siliconed the original and Changed back to them but the prob was still very bad..the slight miss has turned to a full breakdown :P. Everything has been double checked.
ok so replaced ignitor module with a friends..still no deal.
I just dont get it, the car is so well behaved and runs perfect right up untill a mash the pedal, then it sounds like anti lag! like bad popping and cracking.
Seriously i can drive the car perfectly its only when mashing the pedal, its soo weird.
