Hey guys/Gals im into model photography and i was wondering if anyone else is into it... i normally do fashion lingere or bikini shoots and have started incorporating cars into the shoots due to my love of imports. if anyone has any examples of their work i would be really interested in seeing it!
i will post up some of mine when i get home 2nite.
https://www.sau.com.au/forums/topic/279542-model-photography/
usually prior to the shoot you would get the model to sign the rights over for the use of the picture. Copyright usually subsists with the photographer and you grant a licence to the model to use the photo for her own use if he/she requires it.
I don't have an example contract on me right now but they are easy to find.
Thats what i was trying to say.. with copy right and all. Just in a less professional way. haha
Yea took me 2 seconds to find one on google few weeks back :/
heheh no worries ian:
So this was my 1st ever model shoot. I had a blast and overall im quite happy with the results, but i will leave it up to you for feedback and all.
Shes a young mum, and wants to show everyone that you can still look and feel great after having children.
1.
2.
3.
4.
Hope you like it :cool:
thanks,
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
