Hi guys, have heard that the standard r34gtt cooler fits straight in place of the stock r33 cooler. Can anyone confirm this for me?
Also, I have read that the stock r33 cooler is efficient up to 180rwkw, the r34 cooler is supposedly thicker and more efficient, does anyone know how much power its good for?
https://www.sau.com.au/forums/topic/27956-r34gtt-cooler-into-r33/
  • Replies 40
Hi gts,
yeh I realise its not going to give the gains that a FMIC will but at 1/10 of the price (approx $150 for 2nd hand) it seems to me to be fairly decent value, unless someone knows otherwise.
how much better than r33 one, does anyone have any figures on it (Ive tried a search couple of times but Ive only found general statements bout efficiency).
hey chief i bolted an R34 cooler into mine, straight swap, no problems.
the thicker core may be a slight disadvantage over wider/thinner cores but when the cooler is ducted correctly it shouldn't be a drama. no increase (discernable) in lag is a big advantage and if you are using it as a road car then most I/C's probably work as heat sinks so the extra 60% ?? vol is an improvement.
Responsiveness may beat kW in many situations.
i have no hard figures on the improvements.
i have one on my R33 with the r34 ducting etc to the cooler and the car is also mdded and hasnt pinged or anything strange,
and doesnt seem to care too much
i could notice on my previous R33 when enough was enough and you had to let it cool. so yeah for the small price its worth it, and if you can set up a decent water spray for a few dollars more then thats alot more efficient that stock but yeah still no FMIC
damn right, they are cheap if you sell the old one, but the best bet is to ensure that you have proper ducting of air onto the cooler by sealing all sides and proper venting into the wheel arch. the wheel arch has a negative pressure (as i understand it) therefore you will get good airflow and velocities thru the cooler (remembering it is a thicker core than the '33) if you take the time to cut and mesh this section.
Agreed, its not a perfect solution for peak HP but for most road applications the responsiveness should leave you ahead. Read rev210's posts if you want some validation from a more authoritative source.
  • 11 months later...
Hi guys,
Sorry to bring up an old thread, but I though I would just post my feelings on this topic again.
I just bought and installed an R34 gtt intercooler on my car, I would say that based on my initial impressions, I think it was worth it. :D
Dont get me wrong, Im not seeing masssive differences in power, but I can defiinately feel a significant difference between the new cooler and stock one.
It feels like your upping the boost 0.1bar (or so) more.l As far as actual power differences go I have no idea what sort of improvement I have achieved, but I think that to really notice any difference, you would have to improve power levels by at least 5% so Im assuming were looking at 8-10rwkw.
This is all at 0.7bar mind you, so Im not sure if that makes any difference.
Does anyone have or heard of any real figures on improvements with this sort of upgrade? Would be interested to know.
  • 2 months later...
Hey people, I'm looking at doing this mod if my car doesn't sell quick enough, just to get some extra power :)
How much boost would the R34 intercooler be able to cope with? Note this would be for short bursts just to dart through traffic etc.
12psi? 10psi? I have a good turbo :D
How much boost on standard turbo would the R34 intercooler be able to cope with? Note this would be for short bursts just to dart through traffic etc.
12-13psi
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
