The guards are the issue.
I have a VeilSide GT-R front bar on mine and I was able to coax it into place with a heat gun and a little gentle persuasion. You will need a warm day to do the job because the heat needs to be uniform over the bar when you bend it.
Needless to say the paint didn't appreciate the effort and it wrinkled slightly.
If you were going to start with a bar that needed painting, it can be done.
The other option is to buy a bar that has the GT-R look but the Gts-25t fit. Here's a link to Carmate that have them: CARMATE.
Good luck!
ah ok..but it will fit like mount up..??
the fender are different but towards the body not front..or mayb coz of the headlamps..
i heard gtr front bumpers wont fit series2 coz of the headlights are different, but fits on series1 33
or was this just a load of crap....
basically gtr bar wont fit gtst. like every1 said the guard issue and yes headlight issue too. gtr headlights are diff from both gtst series and wont leave an even gap by doing this.
go on ebay, search seller mybodykits, gtr bar is like 280 and all u need is paint and it will bolt up. i bought one a while back and fit mad. only thing like all aftermarket bars, u will have to place 2 packers under the bar at the headight corners to close the gap aftermarket bars leave or buy an aftermarket reo bar too.
this bar doesnt have the in-built grill that most fakes/copy have..
and thats spoze is the problem..esp on series 1..u get a gap.
the bumper iam getting is a fake aswel..but yea..its an odd one..so yea im just try to suss it out 4 now.
the only thing thats got me puzzled is wer the bumper bolts onto the corner of the front fenders..
ive seen this doin before on sereis2..and one guy made it..
i'll try find a pic.. and show u wat i mean.. his bar aswel didnt have the in-built grill..
  • 5 years later...
  • 1 month later...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
