Hi all,
Selling my Volks as I have upgraded to 19s. I would really like to see this on another sedan if possible. Offsets would suit coupes as well but won't look as agressive as compared to on a Sedan.
18x8 +33
18x9 +31
Tires are 225/45 Sumitomo HTR ZIII 70%; 245/45 50% $1100 when new
Tyre review here: http://www.tirerack.com/tires/tests/testDisplay.jsp?ttid=93
Come with additional CF Rays wheel caps as well which cost me an additional $200
Selling the lot for $2800 pick up Southside Brisbane. If you are planning to stick this on your sedan, you will need to have been lowered at least 1" and rolled your rear guards.
Will also suit R32,33,34.
Wheels are flawless and the closest you will get to brand new!
PM for more info.
https://www.sau.com.au/forums/topic/279581-fs-volk-gts-top-secret-gold/
  • 4 weeks later...
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
Boxing day sale reduced to $2300!
Perfect for lowered V Sedans, R32,33,34 and most Nissans!
What you get:
Wheels x 4 in immaculate condition
Sumitomo HTR ZIII performance tires with plenty of thred left
Rays CF Wheel caps
* If purchased at $2300 will thrown in a set of used Blue rays duralumin lug nuts as well!
Treat your car to a set of these for the New Year! :D
  • 5 weeks later...
  • 1 month later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
