Random R32, R33 Parts: Radiator, Brakes, Castor Rod, Seats Etc
By funkymonkey · Posted
6.5” drops right in. Had to notch the speaker frame to accomodate the rivet for the child seat restraint mounting point. -
Time to remove the crappy factory rear speakers and child restraints so I can put the rear shelf back together. -
From memory it's a ROM thing. Each option that is added will change the ROM they use for the ECU. Some times it's just enabling it via a tool.
Thanks for the response Guys , so far the mechanic has topped up the coolant and I haven't noticed and further leaks , I'm going to see if there local workshop who might have a bit more expertise on the imports. if the pump needs replacing I'll give you guys a heads up.
