hi guys just like to ask what my prob may be
when your in 1st and you take off from a set of ligths and nail it.. it gets to rev limiter and bounceses on it 1-2 times then flat lines (cuts out) until you go 2nd
what would cause this prob??
Nat
Edited by mr-r33
https://www.sau.com.au/forums/topic/279612-r33-flat-lines-once-it-hits-limiter/
  • Replies 44
Posted Images
:down: You must be joking...
all am trying to do is work out what is up with my car and what i put in the first post was the best way to describ it
so pls if you can't help dont post
and if every one wants to act like a 12yr old here you go
PS like no one on this forum has never hit limiter in there car....just to add i dont do it on the streets as i dont drive the car. my misses dose...i only drive it on the track
oh oh befor i for get i know i cant sell so no point telling me something that i all ready now.
Of course it flat lines - it's hit a limit. It's doing exactly what Nissan designed it to do. It protects the engine from idiots.
Actually Daniel, the problem is somewhere between the left ear and the right ear - I think it's called a vacuum.
do you know what flat line means?...what i'am saying is it gets to limiter then it's like you turn the key off and restart it once in 2nd
thanks i know i have a vacum between the ears it absorbes all the info better then rocks
Edited by mr-r33
Is that so?
You're the one acting like a 12 year old. You're driving like you're playing a computer game? Learn how to drag race properly. Both power and torque curves stop way before the rev limiter - there is simply no need to take the engine RPM that high.
sorry ppl for wasting my time here i guess the question is just to hard for a lady to answer ill go to a forum where they no about jap cars not a forum where they think they no about jap cars
Go to another forum...but before you do, perhaps consider that given everyone here is telling you how much of a jackass you are...you might be wrong in what you are doing and saying? We're not the ones who are going to end up with a conrod through our engine blocks. And I'll warn you...you will get the same responses from any knowledgeable forum. What really made me laugh is you saying "Jap cars" as if this is a Jap car specific "problem"? Go back to playing Need For Speed you idiot.
Edited by Birds
Is that so?
yes that is so not that long a go i went to oran park skid pan for the first and this is when i notice the the prob
not to be smart but i dont play computer games or game consoles....i dont drag race and the only time i have ever hit the limiter was at the skidpan when i spun out (i'm not saying i know how to drive)...and the car has only been rego for 2weeks or there abouts and the misses drive it as i'm on my green P's and have my 2 kids in the car most of the time so to do any thing of they above with kids in the car or evern with out kids in the car your an idiot
hey man i'm just trying to work out what is up with it
Why is the problem bothering you if the only time you hit the rev limiter is at a skidpan?
I can do anything in my car without hitting the engine rev limiter...even burnouts...but they aren't really my thing. Shift long before the limiter and practice throttle control...then you will be fine. I'm guessing your ECU shut down your engine, as is the function of a rev limiter, to protect it. Much the same thing happens when you hit 180km/h in a JDM vehicle.
hmmm ok thank you....i was chating to a mate a few days a go and he thinks it may be the CAS as the car was in a aco by the previous owner.
Well a quick fix for this problem, Firstly BEFORE you get to the redline you need to rapidly remove your right foot/shoe from the accelerator pedal. Then with your left foot/shoe you need to press in the pedal furthest to the left ( this is called the clutch pedal ) Whilst that pedal is depressed , With your left hand you need to reach over and grab the gear stick and gently but assertively select the next gear. When this sequence is complete gently but assertively release pressure from the clutch pedal ( your left foot/shoe ) until pedal has completed all of its travel. Resume acceleration by pressing the pedal furthest to the right ( Accelerator pedal )
Hope that helps your problem :)
cheers man now i see what i was doing wrong...i was flat changing and for getting about lifting the right foot/shoe befor changing gears :):ninja:
i understand wat ur saying with the (flat line) bit if its a factory computer i cant say from experience cuz ive never had a standard computer but dont they have sum sorta protection cut that basically stops the engine from revving completely..... my mates lil sss pulsar in lil fits of rage hes just hold it on the rev limiter and it would just die in the arse or as old mate says it flat lines as if the fuel or ignition had been shut off for a second.... not saying its the same thing but i defo noticed it.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
