Hey Guys, have got a few things for sale, will keep adding to the list as i find more stuff
R32 GTR Crank Angle Sensor $50 1 SOLD, still have 1 more
12x Coil packs $80 for the lot all good, pick and choose for what you want
R32 GTR Steering Rack with tie rod ends $150
LH Door(White and complete) $220
Bare steering column $20, Indicator stalk etc sold
Glovebox Lid $5
Tailights(White Surrounds) $50 each or $90 pair
STD Fuel Pump $70
Drivers Side Headlight $70
Starter Motor $50
Front Crossmember $100
STD Turbo dump pipes(pipes that bolt directly onto turbos) $50 pair
HICAS Computer $50
ATTESSA Computer $50
G-Sensor Located under Centre Console $250
Bilstein Front Shocks and springs(Dont Ask what the spring rate is and im not testing them either as im selling them cheap) $50 pair
Harmonic Balancers x2 good condition for both $20each
Near complete rear cradle, minus shocks and the HICAS setup(including rod ends etc) Diff good, rear brakes good $1200
Plastic Pipe that runs across front of car to the Twin BOV $50
I/Cooler hose from bottom of under left side guard to intercooler $20
I/Cooler hose from intercooler to under right hand side of guard $20
I/Cooler hose from above to the plenum $20
Carbon fuel canistor $10
Power Steering resevoir $10
Factory power steering cooler $10
AC Fan $20
Plastic crossover pipe that runs to BOV $30
R32 GTR BOV's $80
Widscreen washer bottle $5
Wiper Motor $50
Bonnet latch assembly $80
Left and right rear/side panel trims. NOT the quarter window trims but the other ones that are right behind the seat Couple small marks but good condition otherwise, have got Black Vinyl/leather (NOT SURE WHAT MATERIAL IT IS) inserts instead of the normal blue velour trim $50 pair
Thanks guys, also: still wrecking white R32 GTR, heap of bits sold but still some bits etc on there
https://www.sau.com.au/forums/topic/279669-r32-gtr-bits-and-pieces-sale/
Pm replied pointa, if you need to contact me email; [email protected]
Cannot rely to pms till after 4.30 tomorrow due to the forums system....
All good happy with deal. :thumbsup:
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
