Now I know plenty of people have made big power on stock RB25DET internals but having had a good look at the cast RB25DET pistons (in fact many examples of them) I'm amazed that there aren't more failures! Ringlands are the number 1 point of failure on all the pistons I recently looked at ( lots & all RB25DET!).
As an aside the state of my engine internals were bloody excellent when it was pulled down! The pistons are good (apart from 1 with a 2-3" section of RL missing) nil detonation damage, all rods perfect, bores perfect, crank etc... Basically there is ZERO traces of any detonation at all.
Attached is a pic of the failed piston-
https://www.sau.com.au/forums/topic/27967-stock-rb25det-pistons/
Here's what is replacing the old pistons -
Along with a Trust H/G (not O'ring now)
New fuel rail/injectors (top feed & still using the stock plenum - yes is can be done)
I actually have a few better pic's of the CP pistons but they don't want to load up?
The idea behind the 8.0:1 CR is to allow 20+psi boost & more timing on pump fuel all day every day. Well that's the idea anyway ;)
Other engine/turbo mods limited to the follow basics;
I already have a T3/T4 combo (exact housings wheel trims I'm not sure?)
The cams will remain stock (have adj' c/gear already)
The head is just getting a basic clean up (will stick to 7500rpm limit)
Stock manifolds - with a basic port match
TRUST head gasket - stock thickness
The rest is just your usual basic rebuild freshen up
Then the new fuel rail & 550 to 600cc injectors (Bosch most likely)
Everthing else was already in place in the pre rebuild stage (ie. ECU, EBC, intake, exhaust etc...)
Hi Matt good to see your keeping your car, so you can have some more fun at the drags.
I recently got a rb25 with the same thing, 3 pistons with cracked ring lands, apart from that everthing is perfect. I was going to just buy a std one but after seeing all the others fail i though i would build it anyway so i just bought a stuffed one, cost $800 after i sold the turbo and is basically compete and ready to be done properly for 300rwkw. Let us know what you think of nisspeed for future refrence.
G'day Clint,
Yeah mate I'm so glad I didn't let it go! I'm hangin' to get it back on the road, & even more so to hit the track again!
$800 is bloody excellent! Even after a full rebuild using quality components it'll still be a low cost motor. 300+rwkw of 2.5L in a 32 GTS-t is a great combo ;)
I'll let you know how things go re Nisspeed. So far I've got nothing but huge praise for James (Nisspeed). He's got a lot of knowledge & experience with performance engine builds, epsecially Nissan stuff (surprise surprise ;)). He spent ~5hrs going over everything about my rebuild with me last Friday in the workshop. He's kept me informed about the progress of parts. He's taken on every little extra I've requested. He charges sensible prices for top quality work. His motto is built it right the first time & it'll make good reliable power. And he is keen to make up custom parts to suit my requirements for just the cost of the materials!
Hip,
Haha, no death wish dude, just the aim of a 12sec daily driver. Ok I'll tell the truth. You see I bought a 30psi boost gauge ages back & I always felt I was missing out by only using 15psi of it, so soon I'll be getting my moneys worth ;)
Tony,
Yeah I'm expecting a slightly doughy bottom end, I can live with that. As long as it's on full song by 4000-4500 & has a healthy spread of power/torque to ~7500 I'll be happy enough.
Hi Matt, no signs of detonation???? FARK, now I am paranoid again.
I have just seen my pistons and they are all in perfect condition with 'no signs of detonation'.
I thought it was the knock sensor keeping me in line. Mind you it can still detect knock way before my ears can - which probably has something to do with the screamer and me being part deaf (getting old you know).
Those pistons do look nice and shiney Matt, seems a shame to put them inside an engine. I suppose you will always have your souvenir smashed ring land piston that you could polish up and use as a centre piece, if you have any spares, I need an new ashtray:)
With an 8:1, you should be giving 30psi a nudge, just for shits and giggles;)
Go on, you know you want to, dont be weak:D
Naa Hip slicks is cheating.
Steve,
Yeah it doesn't surprise me your pistons are in good nick mate, just about all the ones James showed me were quite healthy looking except for the ring lands (some had 2 or 3 sections cracked). The way I see it there's no need to worry about your pistons, if they let go then it's time to go to the next stage. If they hold on for a yr or so then it's a bonus :)
I plan to make the dud one into a nice little display, gotta' have a few bloke things in the display unit beside all the girl trinkets :rolleyes: I'm sure James can spare a few for ash tray purposes.
The plan is to see what it'll put out in everyday trim & then go for an all out big boost & exotic fuel combo. So yeah well over 20psi should be on the cards. I doubt it'll make much more than mid to high 200's as the turbo isn't up to the task I don't think. Should be fun anyway :)
Matt,
I dunno' mate? Not much. Once I pick them up I'll let you know & you can pick out which ones you want :)
Originally posted by Clint32
TonyGTSt, what did the N1 pistons cost you? you dont hear of GTR pistons cracking the ring lands do you
N1 pistons are not worth it IMO.
$250 each + $200 for rings.
However I got mine for a very good price.
Say close to $800 or so inc. rings. Use Nissan rings. They're good.
GT-R's do break pistons and rods but they are tougher than GTS pistons. It's just that I didn't have the money to stretch to $1,400 forged and my HP requirements are meagre.
If I do 250rwkW I'd be happy.
T.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
