On an R34 gtr ..
After a clutch swap, atessa under load is pushing power to the front
then removing it, and cycling back and forth like that -- creating a bad feeling
on the road under boost. torque meter shows it pushing power to the front.
There are no warning lamps lit.
ECU has been changed over, no difference.
The atessa fluid has been changed twice, and bled several times..
G-sensor checked for correct voltage.. anyway, g-sensor wasn't disturbed.
I believe each of the 4 speed sensors have been checked, or are being checked.
Since there is no 4wd warning light, there are no error codes to scan for..
On the dyno, the problem isn't really noticeable. Just on the road.
Any other ideas on what it could be? what to check for?
Also changed: rims (just a bit wider), new tires (same profile), new brake kit
(was working ok after brake kit swap, I think). And lastly, more power. But not
a shedload more power.
https://www.sau.com.au/forums/topic/279705-atessa-acting-weird/
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
