On an R34 gtr ..
After a clutch swap, atessa under load is pushing power to the front
then removing it, and cycling back and forth like that -- creating a bad feeling
on the road under boost. torque meter shows it pushing power to the front.
There are no warning lamps lit.
ECU has been changed over, no difference.
The atessa fluid has been changed twice, and bled several times..
G-sensor checked for correct voltage.. anyway, g-sensor wasn't disturbed.
I believe each of the 4 speed sensors have been checked, or are being checked.
Since there is no 4wd warning light, there are no error codes to scan for..
On the dyno, the problem isn't really noticeable. Just on the road.
Any other ideas on what it could be? what to check for?
Also changed: rims (just a bit wider), new tires (same profile), new brake kit
(was working ok after brake kit swap, I think). And lastly, more power. But not
a shedload more power.
https://www.sau.com.au/forums/topic/279705-atessa-acting-weird/
