Rear cradle dropped for service, bushes and maybe a respray.
Front coilovers test fitted with strut brace.
5 Stud hubs test fitted....
Restarting on the brakes.
Getting them sandblasted, then anodised, then going to have a crack at rebuilding them with new seals. Will add pics of each stage as it occurs.
Edited by Nic_A31
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5314737
  • Replies 118
Posted Images
Thanks.
R33 GTR Rims...I got 4 with tread for a VERY good price, these should be for the other Ceffy, but I couldn't resist, had to test fit them in the shed tonight,
PERFECT offset and width.
In other news, I rang the nearest sandblaster in the Yellow Pages today....asked for a ballpark figure to blast all 8 calipers I'm doing.....cost?....carton of beer.
Legend!!
Anodising is going to cost me about $150 for all 8
Seals are $100 for per set of calipers, so $200 all up for me.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5321843
Were those gregs rims? If so, nice. Brilliant fitment.
Who's anodizing for you?
Are you going to get like PMU pads or anything like that, or are you just gonna go bendix? The ultimates that I put into toms gt-r were pretty good, but they probably got nothing on the Project Mu pads.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5321882
Were Greg's rims yes.
Zinc Coaters in Welshpool are doing anodising, they work day and night, and are on the next street parallel to my work, so easy to get to :)
Pads, dunno, at this stage, all the Nissan pads I've got have plenty of meat left on them, but will upgrade to something a little better later on.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5321918
  • 1 month later...
Fark, the attention to detail is wicked bud, I wish I had the time and money to do what you are doin. Can't wait to see this ceff finished, will look minter!!! Any luck with that digital climate control unit yet or not?
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5379348
  • 5 weeks later...
Solid as f**k.
Will clean cradle down and respray it before it goes back in.
Still deciding on the rest of the rear suspension.
Replaces bushes?
or
Nismo sh*t?
2 Way diff, will be staying, regardless :)
OTHER NEWS:
-Now using an S14 steering rack
-Complete HICAS removal
Hasnt been touched other than that, in....f**k, ages. Stupid other Ceffy is wasting my time!!
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5435530
  • 7 months later...
Aaaaand this little adventure resumes. Unfortunately no pics of today's events, however this is what you can expect to see...
Plans for the next week:
Finish respraying underside of car [sound deadener] (halfway there)
Strip back engine bay, again
Clean and re-assemble front suspension, LCA's, steering rack, etc to crossmember.
Clean and re-spray cradle
Clean and dye C33 Laurel Dash, fit, and wire up extra's
Clean interior
Weld up old intercooler in/out panel provisions
Plans for fornight/onwards:
Strip GTR cradle and put it all onto current cradle (with solid bushes)
Remove front and rear windshields
Plans for month/onwards:
Respray engine bay
Respray car?
Plans for next 3 months/onwards:
Decide on powerplant/drivetrain, build and fit
Replace all the bits I raped off it for the other one (ie 5 stud, brakes, coilovers, etc)
This is "The Hump", it's in a billion pieces, the car hasn't moved a millimeter in nearly 2 years, and for the first time since then I'm putting shit back together rather then dissasembling.
VOTE TIME
RB25DET NEO
RB26DETT
RB30DET/T
VQ30DETT (added challenge)
SR20DET (shitter diesel truck spec)
Fully built VK56DE+TT (For Ultra-LOLs / pant-shitting)
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5762263
sound deadener
Dont use anything from any commercial shops ( autobarn, auto1 ) as they are all shit and dont set and harden as i've stated before, talk to a panel beater/sprayer( or toffy) to get some real stuff
if you dont want to keep it to a specific cc's then rb30 + 25 head (copy front facing intakes are cheap enuff)
VQ30DET if u want head aches, stuffing around but finally a great motor
or SR20DE+T/SR20DET if you like trucks
more info on "dye C33 Laurel Dash" and cost etc pm etc
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5766733
VHT Vinyl dye...comes in a spray can, its around $15.00 mark.
Clean the surface down real good 2-3 times, spray the vinyl on, let it dry, repeat.
It's a dye rather than a paint, and actually sinks into the vinyl and changes the color, so its resistant to cleaning agents and fairly resistant against sun damage (although it has faded slightly in my other Cefiro).
Dash looks brand new.
I'll take pics tonight if I get enough daylight after work.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5767281
Got stuck in today stripping the temp. paint in the engine bay, didn't find any rust which is good, some of the factory paint was chipped up and flaking, dunno why.
Gave it some primer over the top of the area's I did strip back. I'll strip down the other area's tomorrow, and strip back the primer I laid, then apply 1 coat of primer, still can't make my mind up as to paint it myself in high temp acrylic or just get it done same time as the whole car.
These things make life breezy
Anyway, some blurry shithouse pics off teh new phone.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5778980
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
