Rear cradle dropped for service, bushes and maybe a respray.
Front coilovers test fitted with strut brace.
5 Stud hubs test fitted....
Restarting on the brakes.
Getting them sandblasted, then anodised, then going to have a crack at rebuilding them with new seals. Will add pics of each stage as it occurs.
Edited by Nic_A31
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5314737
  • Replies 118
Posted Images
Thanks.
R33 GTR Rims...I got 4 with tread for a VERY good price, these should be for the other Ceffy, but I couldn't resist, had to test fit them in the shed tonight,
PERFECT offset and width.
In other news, I rang the nearest sandblaster in the Yellow Pages today....asked for a ballpark figure to blast all 8 calipers I'm doing.....cost?....carton of beer.
Legend!!
Anodising is going to cost me about $150 for all 8
Seals are $100 for per set of calipers, so $200 all up for me.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5321843
Were those gregs rims? If so, nice. Brilliant fitment.
Who's anodizing for you?
Are you going to get like PMU pads or anything like that, or are you just gonna go bendix? The ultimates that I put into toms gt-r were pretty good, but they probably got nothing on the Project Mu pads.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5321882
Were Greg's rims yes.
Zinc Coaters in Welshpool are doing anodising, they work day and night, and are on the next street parallel to my work, so easy to get to :)
Pads, dunno, at this stage, all the Nissan pads I've got have plenty of meat left on them, but will upgrade to something a little better later on.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5321918
  • 1 month later...
Fark, the attention to detail is wicked bud, I wish I had the time and money to do what you are doin. Can't wait to see this ceff finished, will look minter!!! Any luck with that digital climate control unit yet or not?
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5379348
  • 5 weeks later...
Solid as f**k.
Will clean cradle down and respray it before it goes back in.
Still deciding on the rest of the rear suspension.
Replaces bushes?
or
Nismo sh*t?
2 Way diff, will be staying, regardless :)
OTHER NEWS:
-Now using an S14 steering rack
-Complete HICAS removal
Hasnt been touched other than that, in....f**k, ages. Stupid other Ceffy is wasting my time!!
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5435530
  • 7 months later...
Aaaaand this little adventure resumes. Unfortunately no pics of today's events, however this is what you can expect to see...
Plans for the next week:
Finish respraying underside of car [sound deadener] (halfway there)
Strip back engine bay, again
Clean and re-assemble front suspension, LCA's, steering rack, etc to crossmember.
Clean and re-spray cradle
Clean and dye C33 Laurel Dash, fit, and wire up extra's
Clean interior
Weld up old intercooler in/out panel provisions
Plans for fornight/onwards:
Strip GTR cradle and put it all onto current cradle (with solid bushes)
Remove front and rear windshields
Plans for month/onwards:
Respray engine bay
Respray car?
Plans for next 3 months/onwards:
Decide on powerplant/drivetrain, build and fit
Replace all the bits I raped off it for the other one (ie 5 stud, brakes, coilovers, etc)
This is "The Hump", it's in a billion pieces, the car hasn't moved a millimeter in nearly 2 years, and for the first time since then I'm putting shit back together rather then dissasembling.
VOTE TIME
RB25DET NEO
RB26DETT
RB30DET/T
VQ30DETT (added challenge)
SR20DET (shitter diesel truck spec)
Fully built VK56DE+TT (For Ultra-LOLs / pant-shitting)
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5762263
sound deadener
Dont use anything from any commercial shops ( autobarn, auto1 ) as they are all shit and dont set and harden as i've stated before, talk to a panel beater/sprayer( or toffy) to get some real stuff
if you dont want to keep it to a specific cc's then rb30 + 25 head (copy front facing intakes are cheap enuff)
VQ30DET if u want head aches, stuffing around but finally a great motor
or SR20DE+T/SR20DET if you like trucks
more info on "dye C33 Laurel Dash" and cost etc pm etc
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5766733
VHT Vinyl dye...comes in a spray can, its around $15.00 mark.
Clean the surface down real good 2-3 times, spray the vinyl on, let it dry, repeat.
It's a dye rather than a paint, and actually sinks into the vinyl and changes the color, so its resistant to cleaning agents and fairly resistant against sun damage (although it has faded slightly in my other Cefiro).
Dash looks brand new.
I'll take pics tonight if I get enough daylight after work.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5767281
Got stuck in today stripping the temp. paint in the engine bay, didn't find any rust which is good, some of the factory paint was chipped up and flaking, dunno why.
Gave it some primer over the top of the area's I did strip back. I'll strip down the other area's tomorrow, and strip back the primer I laid, then apply 1 coat of primer, still can't make my mind up as to paint it myself in high temp acrylic or just get it done same time as the whole car.
These things make life breezy
Anyway, some blurry shithouse pics off teh new phone.
https://www.sau.com.au/forums/topic/279725-ceffeh/page/6/#findComment-5778980
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
