Hey guys,
I've got my old rb26 that i'm stripping. Almost everything is available apart from the injectors, harmonic balancer and coils. I havent stripped it back yet but will start soon so photos will crop up in the not too distant future.
Fuel Rail + Regulator $100
Intake Plenum $100
Injector plate $300
Throttle Bodies and linkages $300
R32 Turbos x2 Good Cond bugger all shaft play $300 for the pair
R32 Turbos x2 appear to be recently rebuilt, sweet fa shaft play. Came off fresh motor from jap land. 1 has a stiff wheel from not being used for ages but should free up just fine when installed and run. $200Ea
Stock Cam Gears 2x pairs available $50 per pair
Brand new nissan timing belt $70
Water Pump appears to be near new $50
Wiring Loom $400
CAS Sensor and bracket $200
Stock r32 dump pipes 2 pairs available $30 a pair
Rocker Covers (no valley cover sorry :bunny: )$100
Cam Cover $50
Starter Motor $50
P/S Pump $50
HKS SSQV with weld on adapter $200
Brand New Nissan Thermostat $30
Engine Mounts, look to be good cond $80 (for Left & Right)
Oil Cooler assembly $150
Manifold x2 $100 (for both)
GTR Sump including diff $350
RB26 Flywheel with stock clutch appears to be in good nick $150
2x A/C Compressors unknown condition but look good $80 ea
Oil & Water hard Lines (the ones running above the turbo's) $100
Dipstick and Tube $20
Oil Cap $10
Cam belt idler and tension pullies 2x sets $30 per set
Alternator recently rebuilt $60
Manifold Heat Shields $40 (pair)
Heaps more parts for sale, thus i'll try and get them up shortly too!
Block, Head, Crank, pistons, rods etc will all be for sale once i've stripped the motor to look at their condition.
Please contact me via p.m. and i shall try to get back to you asap!
Cheers,
Rob
Hey mate i cant send a pm for another hour so i'll shoot a reply here,
Thermostat will cost $6 to post in a postpack satchel.
Only need one thermostat but its not in the bottom of the radiator, its in the block near the waterpump. Im selling the mechanical thermostat that controls the flow of coolant through the radiator.
The item thats in the bottom of the radiator is a thermostat switch for the overheat fan which i unfortunatly do not have a spare to sell :)
Hope this helps!
Cheers,
Rob
ill take the Brand New Nissan Thermostat $30.. pm me price posted to 3355
can someone confirm only one need for r32 gtr, located bottom of radiator?
Edited by WhO
Hey guys,
Sorry for any slow replies, i can only seem to send 1pm per 30 minutes which is making things a bit tricky! I'll endeavour to reply as soon as possible however i am only usually home after 7pm and have limited internet access during the day which makes replying a bit tricky.
Can all enquiries be directed to all_performance_imports@netspace.net.au from now, this e-mail i check every day and can reply to quickly!
Dipstick and tube - sold pending payment
AAC valve & 1 cam gear set - sold pending payment
Hey guys,
For some reason my mail is bouncing out of the e-mail address all_performance_imports@netspace.net.au
so please send all mail to all_performance_import@netspace.net.au
Sorry for the inconvenience guys, damnn :)
JFKGTR - Unfortunately i dont have the rubber flex bits for sale as im using them on my new motor :ninja: Plenum is available tho for $100
To all, im in Adelaide btw and pickup of parts is fine!
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
