gday all
i have just registered to this forum, as you all would be the people to ask about this.
I dont have a skyline, i have a Nissan GQ Patrol, but i am wanting to use an Oil catch can as a pressure vessel up to about 100-120PSI, will it be able to cope with it? if so, can you please point me in the direction of where i can get one. I have an endless air compressor setup in my GQ, (so that i can inflate tyres and run the rattlegun etc etc) but i have a problem where it sucks the oil down into the pump to keep it lubed, but after it leaves the pump, it goes to the tank. some of the oil sumps in the tank and thats what i want, i dont want any oil comming down the airline into my tyres or tools, so i thought that if i had an oil catch can setup, then i could use that to seperate the oil from the air, and the possibly re-circulate the oil back through the system. is this possible?
if more explanation is needed, please let me know.
cheers
Jbates58
https://www.sau.com.au/forums/topic/279776-oil-catch-can-info/
I would be concerned that an oil catch can could not cope with that level of pressure.
Have you thought of using a "in line" water filter to catch the oil? It would be designed to do this job and cope with the pressure, they are quite small and come with a button to release the water.
i had thought about that, but i would like something that i could use to re-circulate the oil back into the compressor. is it hard 2 make a catch can, i am good on the tools, but i am not sure how to get it to work, whats in a catch can that catches the oil?
cheers
jbates58
Try supercheap auto (ok stop laughing), they have solid aluminum ones, the only question mark is if the paper gasket seal might pop, the tops are held down with bolts, you could remove the gasket and try some silicon to seal it back up again.
If you get the one with the sight level (plastic bits), you could remove the adapters and plug the holes up, all the fittings are threaded so you can put your own high pressure ones on.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
