Hi guys, I'm in a bit of a rush to get my car ready to leave for alot of work that will be completed in november. So I have finally gotten around to spending some time with the ratchet and getting off the parts that I want to sell.
What's remaining that I would like to get rid of today are ;
Genuine Ganador CF finish mirrors for r34 with the blue tinge lens.
$500 outright or $400 swap with standard mirrors.
Work S2R rims , good rubber all round, 18x9 , 18x10.5, good agressive offset, fill r34 guards, rears will need to be rolled. $1500 or $1200 with trade for any r34 5 stud stockies/na stockies that will fit.
Apexi AVC-R, good working order, $350
Signal CF bonnet with nose piece, $1200 or $900 swap over
Pair of Recaro Millenium with r34 rails, small rip on passenger seat from my belt, apart from that i'd give em a 7.5/10. $ 800!!!
The fabled TK dash, $750 or $550 with swap of standard cluster.
All pics of everything can be seen in my other threads.
All prices negotiable,
i'll be pulling this shit out all day so sms me on 0421 120 034.
Thanks ya'll.
Mods, if you'd be so kind to leave till around sun down, that'd be appreciated.
Located, inner east.
https://www.sau.com.au/forums/topic/279777-pulling-parts-of-my-car-today/
Always intended on going Craft Square's so still not sure =/
eat the pudding eat the pudding eat the pudding eat the pudding eat the pudding eat the pudding eat the pudding
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
