Hks Evc Settings
bnr034
 Share
I am a bit confuse how to set my HKS EVC 6
the thing i am confuse with is the "Boost MAP Correction Mode"
The thing i dont get is that u
- Correction Boost, 40kpa
- throttle opening sxis to 0%
- RPM axis to 30 x100rpm
Does this setting mean that i am goin to get 40kpa when the car is at 3k rev???
The list of mods i hav on my GTT are:
-Full Exhaust
-Air filter
-Splitfire
-HKS fuel pump
-FMIC
Is that a good settings to hav on my car???
-Full Exhaust
-Air filter
-Splitfire
-HKS fuel pump
-FMIC
the manual is confusing and it is better I think to find a place with the software that can
program the boost controller. Unless you have a particular issue it is best to set it up with
a target boost rate - and switch off all the various mapping modes it has. The initialization
procedure is very important as well. If that isn't done right it won't behave right.
the think is that my MAP is set to 85Kpa and when i drive sometimes it hits 119kpa.... or sometime the car will just choke( apparently its a safely feature on the GTT stock ecu). wat i want is to have full boost around the 4k mark. and hold it at around 90kpa.
Do i need to reset my evc??
If i do since the turbo side of thing is stock wat would i set my exhaust bypass be??
Swinging valve or Poppet valve type?
can't help you further, one tuning shop I went to didn't install it right. Second place couldn't program it right,
final place, an HKS dealer, seems to be on top of it.
 Share
    • So I've been working on the car a fair bit, doing a lot of little things. Preparing some projects for this winter, as I'm taking 13 weeks off very soon for parental leave. Have my second kid on the way and he's due any week now. I'll need something to do while he's sleeping. I also usually take the car off the road in about a month and a half, until sometime around the end of March.  Still making slight adjustments to my tune, as the cold weather settles in. I've also had to start dropping boost and tire pressure as the weather gets cooler. It's getting very swirly at highway speeds. I drop to 20psi at 20C and 18psi spring pressure at 10C IAT's. I'm currently on 255 Falcon RT660's, but may look into running 275's next summer. They will fit, but barely. Might have to raise the rear a tad.  I'll start redoing my exhaust Monday, as I have the week off. I currently have an oval center muffler and cannon rear muffler. I've been told more then once from people behind me that my rear bumper is going to catch on fire one day. Seems I blow 5-10 second flames after doing a pull. No clue if that's the WMI, as I've never been able to do that before with other cars. I wanted to angle my tip down a tad so flames are pointed down and away from bumper. I also wanted to take the opportunity to reconfigure my exhaust line. I'm going to move my oval muffler to the rear with a pie cut angled tip and put in a new smaller round muffler in the center. I've rocked cannon mufflers on this car for the last few years and want to transition back the oval muffler look. I've also been looking for a stainless project to try out the new solar flux I bought. I'll post pictures on Monday, should be able to wrap that up in a day.  I'm also picking up another rear subframe this week. I wanted a second so that I could modify one with a gk tech anti squat reduction kit during the winter, and still be able to keep the car a roller so I can back it out of the garage if needed. I will also be caging it this winter. More on that later. Lastly, Speedtek still hasn't given me diddly squat. Every week for the last 4 weeks, they have been saying next week. They told me Friday to expect a shipping label that day to ship my two bad sets of ring and pinions back and nothing. There's definitely been more contact since I started destroying their company any chance I get on Facebook, but it's still just words without action.
    • Have you done a pressure test on your intake/piping? Cleaned your IACV and Cold start valve?
    • Bit of a dump of ones I saw on my trip. I also have a heap from daikoko but that’s technically not  on the street
    • i was thinking that the 2 wires that go to the sub from factory has some sort of preamp like you mentioned and also a lo Pass filter to get just bass. now that will only use 1 channel and that really should be all i need for a sub? if i was trying to put a set of speakers in the back i can understand cutting into the left and right speaker wires. i will try how im talking about doing it and if that is crap i will do it the way of all wires. thanks for the input guys.
    • Challenging mig welding thin Aluminium pipe and trying to fit it in, having to bend and twist, but got there in the end. Fits really well and can easily get a socket wrench in there now to put it on/off. I'm in the middle of another project, so haven't installed the suction pipe yet. I'll post some pictures and results when i do.
