Car is a R33 GTS-T with a HKS GT2835 Pro S kit, built motor 270rwkw on about 1.2bar. I bought the car about 3/4 weeks ago and it has always had a bit of engine noise at idle. I passed it off as it has forged pistons and thought it was them. Motor has'nt used any oil since ive had it.
Lately when i turn the car off it does'nt have that trade mark ball bearing turbo wind down, instead it has what sounds like crunchy bearings lol. Today as i just got it onto boost it made a scraping noise so i backed off. Then later in 3rd gave it half throttle and it could barely boost :bunny: . Tried second and it was spooling ok but then that scrape noise again. Babied it home and now it's reasting.
Here's a vid
http://www.youtube.com/watch?v=GK__sdPQcz0...re=channel_page
It has shaft play up and down, back and forward.
How much would a new core be for this turbo?
https://www.sau.com.au/forums/topic/279783-hks-gt2835-pro-s-not-sounding-good/
gone.
could be seals etc, but now will need new wheels, shaft, seals and balance.
ie a genuine BB garrett core (no front/rear comp covers) is around $800USD
for a rebuild expect around $800 to $1300
good luck, and yeah go a rebuild after getting as many quotes as possible. interstate quotes arnt an issue, honestly
GCG sydney
ATS or MTQ adelaide
Hypergear in melbourne
Normally the grinding noise came from the bearing cartridge, Its a common issue with BB turbo caused from engine oil contaminations. If your wheels and shaft are in good condition its just matter of replacing the bearing cartridge and seals. The small chips on the comp wheel can be machined off. cost wise is about $800AUD for every thing. You are likely needing a inline oil filter before fitting the turbo back on.
If you look on the turbos ID tag it should show a model number and or a cartridge number .
A HKS GT2835 Pro S turbo is basically the cropped 84 trim version of the GT30 UHP turbine with a 71.1mm OD GT35 series compressor in 56 trim .
According to my notes its cartridge number should be 700177-3 , or in long number speak 700177-0003 .
My list shows the unit number as 700382-19 for a 2835 56T , but this may not necessarily be a Pro S unit number because they have RB specific turbine and compressor housings .
Cheers A .
I'd be wondering what's made its way inside to damage the wheel in that manner.
The outside of the wheels are perfect so if the cartridge/bearings are failing its not major yet as the wheel hasn't touched the sides.
It more looks like bits of debris/dirt or similar has been in there at one or more points in the turbo's life.
You would replace that wheel too :P
Perhaps the turbo was swapped out just before you purchased :(
Make sure you pay some $$$ to find out what the failure was before getting too excited with the new turbo. If its lack of oil and so on there could be slightly blocked lines/pressure issues and other similar problems that if not fixed, will kill the rebuild turbo as well :)
There there's oil feeding pin under the oil feeding port. The end pin size on it is 20 thou which delivers oil to your bearings. Normally that gets blocked with all sort of dirt. Your turbo starvs from oil and cook the bearings.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
