Torques Posted July 22, 2009 Author Share Posted July 22, 2009 Many thanks for the information ... much appreciated. Could somebody please fill me in on the R32ECU vs. R33ECU? VVT to me is a mechanical system that changes the duration/valve timing. Is the R33ECU somehow managing the VVT? Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4728801 Share on other sites More sharing options...
PM-R33 Posted July 22, 2009 Share Posted July 22, 2009 Yes it activates it and switches it off at a pre-assigned RPM point. Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4729043 Share on other sites More sharing options...
Torques Posted July 25, 2009 Author Share Posted July 25, 2009 Yes it activates it and switches it off at a pre-assigned RPM point. Alright, So it seems there is no easy and 'cheap' way getting an ECU that does it all and involves a no clutter/plug and drive installation. I will start out by upping the boost via a ball/spring bleed valve so I get a feel for how the car reacts to more boost. In addition I have to buy a good boost gauge. I found one with a peak hold and peak warn function: Boost gauge I think it looks promising ... Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4734998 Share on other sites More sharing options...
PM-R33 Posted July 25, 2009 Share Posted July 25, 2009 Hmmm gauges look allright. Run 10psi through it and it'll love it. Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4735005 Share on other sites More sharing options...
SiR_RB Posted August 4, 2009 Share Posted August 4, 2009 even the r34 gtt turbo is limited to 12 - 13ish PSI, due to the fact that they have the ceramic rear exhaust turbine. although they have the slightly bigger rear housing they can make abit more power... Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4749375 Share on other sites More sharing options...
Torques Posted August 4, 2009 Author Share Posted August 4, 2009 Hello again .. Thanks for all the answers Someone mentioned to me that a standard R34 GTT turbo would fit? But can it run higher boost? Cheers .. Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4749124 Share on other sites More sharing options...
chopsider Posted August 4, 2009 Share Posted August 4, 2009 850 for a hypergear highflow. Thats what i got. My boost goes up to 17psi -18psi no problems eh??? Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4749955 Share on other sites More sharing options...
chopsider Posted August 4, 2009 Share Posted August 4, 2009 [should do no probs Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4749956 Share on other sites More sharing options...
chopsider Posted August 4, 2009 Share Posted August 4, 2009 what s the size of the 33 s2 turbs? Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4749960 Share on other sites More sharing options...
PM-R33 Posted August 4, 2009 Share Posted August 4, 2009 Same size as a series I turbo. They are no different in power other than the series II turbo spools up by a bee's dick quicker. Link to comment https://www.sau.com.au/forums/topic/279831-r33gts-s2-is-there-a-turbo-drop-in-replacement/page/2/#findComment-4750162 Share on other sites More sharing options...
