Originally posted by Josh. H
Hi guys just wondering if anyone could tell me what a M- Spec R32 is, just wondering what exactly the M-Spec has that is different Thanks heaps josh.
Are you refering to a R32 GTS-T "Type M"?
https://www.sau.com.au/forums/topic/27985-m-spec/#findComment-582880
well as with all cars in japan, almost everything could be optioned in but m-spec governs:
- 4 pot front brakes and 2-pot rears
- different front bumper (option of electrical front-lip thingo and option of side skirts)
- rear wiper
- different steering wheel
- velour seats
not sure of anyting else but the main reason (well a eason on its own) to ensure you get a M-spec are the 4-pot front brakes which are the same as those on the Z32 300ZX.
hope this helps,
Warren.
https://www.sau.com.au/forums/topic/27985-m-spec/#findComment-583072
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
