Hi All,
I Have a turbo setup thats a simple bolt up to your standard exhaust manifold for RB20DET/RB25DET/RB30DET.
I'm selling as I've picked up an aftermarket exhaust manifold and going for a bigger turbo. :P
Turbo Specs:
  • Garrett GT3076r (aka 3037S) - Good for 320rwkw on pump or 360rwkw on E85
    • .6 Port Shroud Comp Cover
    • .82 Internal Gate (XR6T Style)
Parts Included:
  • 3" Bell Mouth Dump with Bolts
  • 4" Black Inlet Pipe
    • 4" Black Silicon and worm clamp for turbo to inlet pipe
    • 4" to 3" Reducer Black Silicon and worm clamps for AFM
    [*]Turbo to FMIC hot pipe
    • 90degree Black Silicon and t-bolt clamps
    [*]10mm T3 Spacer with studs and nuts
    [*] Metal Oil and Water Lines
    [*] 14psi Bighead actuator
Required to bolt up:
Cut existing front pipe and weld up a 2 bolt flange
The turbo has done very very minimal km's (5-10,000km's max) and never tracked, it was essentially tuned limped around to work and back then taken off the road.
The turbo is in as new condition and still on the car. I hope to have it removed and packed ready for postage this Thursday.
I will post pics of the turbo package removed when I pull it off Thurs.
$1800ono - Bolt up Drive Away!
Suitable price considering you get all thats needed, oil/water lines, inlet pipe and dump pipe.
Please see the following pics to see what the turbo looks like fitted.
Yes there is a GT3076 .82 IW under there - In this state the car made 302rwkw @ 17psi with cams and 276rwkw without cams.
All pics are of the actual turbo.
More Pics to come when I pull the turbo off on Thurs.
Edited by SLAPS
You dont - I will post. :D
I have had 'heaps' of interest.
Sale is pending as I have some one coming around to look at the turbo tomorrow.
For pickup I'm throwing in the front pipe as I have no use for it due to the vastly different mounting position.
If the sale falls through I will work through PM's based on time received.
Edited by SLAPS
