Hi guys have the following parts for sale from R34 GTT 4 door
Front head lights $300 ono
Rear tail lights $300 ono
Bonnet $500 ono
Boot lid(with rubber seal for boot) $350 ono
Front fenders left and right $200 for pair or $150 each
Stock turbo(no shaft play) $500 ono
Mirrors left and right $200 ono
Nismo gauges(The ones that sit in middle of dash) $100 ono SOLD PENDING PAYMENT
Front Strut bar $50
EMS Stinger V4 with wiring harness $1200 ono
Centre console where radio sits(with A/C controls) $150
front indicators $50
switches for mirrors and power windows $70
Catback exhaust including cat 3" piping $300
pair stock seats $300 pr or $200 ea
Can send pics of required part if requested.
all parts are pick up from Dullwich Hill NSW unless prior arrangment is made.
PM or me for any questions or other parts available
Edited by RBKILA
https://www.sau.com.au/forums/topic/279928-r34-gtt-parts/
  • Replies 69
Any chance of postage as i live on the gold coast in miami?
If so could i please get some pics of exactly what that $150 includes?
Cheers
will post pics tonite,tommorrow at the latest.
https://www.sau.com.au/forums/topic/279928-r34-gtt-parts/#findComment-4726441
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
    • Interesting. I've not dived into the cleanliness of the factory CAS. I'm curious if the variations are less of an issue if the OEM sensor were brand new. Optical sensors if they're starting to get dirt and crap into them as they're getting older would definitely cause issues as they age.   It's an interesting point to keep in the back of mind for me though
    • Hmm. Tough one. Without knowing where the conductivity value is supposed to sit, it's hard to know whether a standard DMM set to an available ohms setting would be able to measure anything. Ohms being the inverse of what we're talkng about and probably good enough for the girls I go out with. But if you want to go all hoity toity with a 4 wire rig - go ahead. It can only be more accurate - just in case more accuracy or repeatability turns out to be required. If you're going to the effort, just go chuck the ohm-mage probes into the car's reservoir and see if you can measure anything at all?
