any chance you can set them up like the nismo gt leds instead of just circle ?
Anything is possible :( But no, the cost would balloon out if I start getting additions made to the current design. As it would require more template cutting and hand soldering by the manufacturer.
oh wow looking good dan!
are these tail light going to come with the whole housing or we have to take it apart and fit the new stuff in the original housing?
cant wait!
Edited by LolWhut
cant wait!
Unfortunately not with the housing, unless I can start picking them up cheaply. Just waiting on some quotes for some laser cut mounts, but the DIY should be fairly stress free. Taking the lenses out just involves putting them in the oven at 80c and then popping them out quickly with a screwdriver.
OK here are some pictures, I apologise for the random angle they’re taken from (I don’t have a tripod) some are with my Pentax, the others with the phone. The phone produces the deeper red which is truer to the actual colour. Either way they look really good in person :)
How much are we looking at at the moment? :P
OK this is still highly dependant on the DIY-ness of the kit. As it currently is, it's not do-able as the supplied PCB's for the LEDs were too fragile. A good day of driving managed to crack a rail supply power to the LEDs so not happy jan.
I've just sent them the diagrams for the new boards to be remade (which are as tough as old boots)
Still hoping for ~$300 a kit, closer to $500 if I supply the tail lights as well. Somewhere in the middle is if I do the install for you.
Too easy mate, the new boards will arrive with me on the 25th June and be ready to go :D
Already had lots of comments from people out and about (I've explained the current 'broken' LEDs haha) they like the look with a more continuous ring.
My only comment based on the latest set of pics is that the inner ring looks 'fuller' than the outer ring, and whether a double-ring in the outer set would fix this up. A bit late now obviously though :)
Yeah the pictures don't do it justice, I wish I could be driving behind my car all the time, at night it's mesmorizing :rofl:
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
