OK here's the final news ;)
The boot LED is as pictured below, it's a silvered PCB with 3M sticky pad. You simply open up the brake light housing and stick the two ends of the PCB in the reflector as shown (bottom-centred) bolt back in place and you're done!
The order has been placed and at the very worst they should be here within 3 weeks (fingers crossed)
Pricing is $27.50 delivered through SAU....a good discount over my pricing on ebay
Edited by 666DAN
  • 4 weeks later...
Ordered 2 sets of the middle Brake LED's today should be good.
Me and a mate have done the Reverse LED's also but we cut the back of the housing out and then stuck the block of LED's in there came out really well i can post some pics if you like they are heaps brighter than the original globes.
definatly interested bud, post away
666DAN, i got a question for ya, how does the LED strip sit in place in the light housing? im assuming it doesnt bounce around in there?
Nup, no bouncing around. It's similar to the one above....comes with 2 screws that line up with the existing holes in the reflector. Also has a 3M adhesive rubber backing, between the 2 fixing methods it doesn't move at all.
Jason it seriously looks like u just put that pic in paint and just erased an area in each reverse light lol..
Dowsetts already broken one of his..
I really like the LED Bootlid brake light.. Ill have to get one next month.
  • 4 weeks later...
OK here's the final news :)
Hey, Dan. I shouldn't have been so keen! I just sent you an order through E-Bay!! That will teach me to read the whole thread!! :happy:
If you get the reverse light kit figured out, I would definitely take one. If you manage to do the fog light in red and white (for second reverse light) now that would be cool!
Cheers. :P
Hey, Dan. I shouldn't have been so keen! I just sent you an order through E-Bay!! That will teach me to read the whole thread!! :)
Cheers. :)
Actually works out $31 delivered now as I can't sen them anything but registered. Yep looking into the other lights at the moment.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
