  Wacky Dee said:
any chance you can set them up like the nismo gt leds instead of just circle ?
Anything is possible :( But no, the cost would balloon out if I start getting additions made to the current design. As it would require more template cutting and hand soldering by the manufacturer.
oh wow looking good dan!
are these tail light going to come with the whole housing or we have to take it apart and fit the new stuff in the original housing?
cant wait!
Edited by LolWhut
cant wait!
Unfortunately not with the housing, unless I can start picking them up cheaply. Just waiting on some quotes for some laser cut mounts, but the DIY should be fairly stress free. Taking the lenses out just involves putting them in the oven at 80c and then popping them out quickly with a screwdriver.
OK here are some pictures, I apologise for the random angle they’re taken from (I don’t have a tripod) some are with my Pentax, the others with the phone. The phone produces the deeper red which is truer to the actual colour. Either way they look really good in person :)
  Charles89 said:
How much are we looking at at the moment? :P
OK this is still highly dependant on the DIY-ness of the kit. As it currently is, it's not do-able as the supplied PCB's for the LEDs were too fragile. A good day of driving managed to crack a rail supply power to the LEDs so not happy jan.
I've just sent them the diagrams for the new boards to be remade (which are as tough as old boots)
Still hoping for ~$300 a kit, closer to $500 if I supply the tail lights as well. Somewhere in the middle is if I do the install for you.
Too easy mate, the new boards will arrive with me on the 25th June and be ready to go :D
Already had lots of comments from people out and about (I've explained the current 'broken' LEDs haha) they like the look with a more continuous ring.
  jrm said:
My only comment based on the latest set of pics is that the inner ring looks 'fuller' than the outer ring, and whether a double-ring in the outer set would fix this up. A bit late now obviously though :)
Yeah the pictures don't do it justice, I wish I could be driving behind my car all the time, at night it's mesmorizing :rofl:
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
