Wolf Ecu Issue
Hey Guys just have a question about the Load Calibration Table on a wolf ecu, i changed the "wolf sensor PSI setting" and now the car isn't running properly. can anyone shed some light on what i have done??? Any any tips to fix this this
Any help would be greatly appreciated
cheers
There is 2 steps to what you have to do.
First set the in the Wolf sensor PSI value and press set. The data is what the ecu will use to mathmatically calibrate the 100% load point after you do step 2 which is to use the "load calibration mode" and select the "WolfPSI load setup" option. Setting a lower boost setting than its tuned for is safer and will result in over fueling and less ignition advance meaning you wont kill your engine.
Really what you have done is pretty bad... If the ecu was laptop tuned and the tuner really knew his stuff he will have optimised the map sensors calibration to the engine meaning you may have a non-linear sensor calibration. You really need to have the guy that tuned it to fix the map to guarantee its 100% correct again.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
