Popping Sound
my r33 is making a popping sound when i am on full boost and it seems to only happen on full accelerator
it sounds very worrying , it is like vrrr ssshhh pop pop pop sorry i dont know how to explain it better
any thoughts would be appreciated
does yours happen under heavy acceleration at about 5-6000rpm on full boost??
That points towards the coilpacks if its happening above 5000rpms, but yeah, regapping your plugs and giving the afm a clean wont hurt
after you done/tryed all thats mentioned by other peeps go buy some AFM cleaner and clean up your AFM, it all helps
+1 i bought some contact cleaner for afm from autobarn @ 20bux and game my afms a clean and the car seems to idle better and feel smoother in the rev range; although it probably aint the problem, i now think its a must as afms seem to get dirty quite quickly.
i seem to be geting this problem aswell, although my s1 r33 seems to spitt out white moke after backing off aswell. havent changed anything yet, coils,plugs probly, could a buggerd turbo be causing all the white smoke??
white smoke = oil
black smoke = fuel
white smoke probably means you've got a dodgy oil seal somewhere in the engine, either piston rings, or turbo.
 Share
    • Looks like a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
    • Luckily I haven’t bought one yet but I’ve had several people tell me different things and was trying to find out what’s going on with my car lol apparently type m had different lover knuckles like the gtr but someone put non type m knuckles on mine Ok on another topic does anyone have a spindle for sale mine is screwed bad lmao
    • The vendor you bought from is a dickhead who can't tell the difference between AWD and RWD bearings. Their eBay listing is one of the first hits too, and is wrong. Any other hit shows the ones that are on your car. A search for GTR rear wheel bearings, unsurprisingly, finds the one you have from Shift. f**king muppets.
    • Got the flat door cards "good enough" for now. After cutting out the arm rest I removed all the stock trim material. Then filled the gap with a bit of Masonite and wrapped it in some adhesive foam to hide the  transitions as much as possible. Then I applied some black vinyl material to the panel with some spray on contact adhesive smoothing the edges as best as I could. Here is how it sits in the car with the door handle and cut down window switch mounted
