OK all you suspension guru's out there. Basically I just want to hear some comments from people on either side of the fence in regards to Whiteline or Tein suspension. I'm looking for something that will stick to the road, and also be fully adjustable as I'd like it a little higher than current due to the front lip scraping on the drivway :x Any comments you have are welcome :!:
https://www.sau.com.au/forums/topic/280-suspension-quandries/
Dont know about GAB shocks but whiteline handling pack will make a big difference 2 your car. their parts are good, but I would recommend that U not let them touch your car. They are a bunch of................
If U can wait and install a good set of coilovers ( height and damper adj) combined with a handling pack ( swaybar, adj camber,castor, suspension bushes etc). Your car will handle better than a Go Kart.
I had my suspension done last week and it feels as if there is glue on my tyres :) I still cant stop grinning.
BTW: good luck with your setup, and keep us posted.
https://www.sau.com.au/forums/topic/280-suspension-quandries/#findComment-9844
I'm a bilstien man. Ive has 5 or 6 sets over the years and they are very good with out being really harsh as I have a bad back. I have them on the r32 and just priced them for the r33 1k approx + fitting. alot of guy want really hard but that is not good you want a little give to let you know when its going to let go.
try quadrant suspension they do alot of touring car teams and rally cars etc they have been in businees for around 20 years so they know their stuff one thing I'm considering is the urathane bushes for the r33 not sure yet they do springs as well. I also got told today that koni docustom built shock for between 800-1200
worth a thought.
meggala
https://www.sau.com.au/forums/topic/280-suspension-quandries/#findComment-9845
Guest 33GTS25
jimbo, you haven't defined what sort of driving you intend to do once you have finished building. For example it would be an absolute waste of money to put strut/sway bars on your car if you intend race on a dragstrip.
where a cars tyres needs to "feel" every available piece of bitumen.
rod
https://www.sau.com.au/forums/topic/280-suspension-quandries/#findComment-9847
Although I will be taking the car to the drags occasionally, I'd rather have the car set up for handling, I want something that will stick around corners. I have 18" rims on at the moment so it's not really the quickest off the line to start with.
At the end of the day I want something I can pull through a corner hard without the fear I'm going to lose the back. I'd also like it a little higher than current as at the moment my front lip scrapes exiting my driveway at any angle and I havn't tried taking on any speed bumps yet :cry: Think BMW handling, and you've got it in one.
https://www.sau.com.au/forums/topic/280-suspension-quandries/#findComment-9848
Guest 33GTS25
i dont know what your budget is like but have you considered some kind of front lifting system such as the diablo uses which operates via a cockpit button and lifts/lowers the front by 100 mm
this type of setup would reduce your need to lift the car as, its pretty hard to "lift" your car and achieve maximum cornering ability
remember that you want to acieve the lowest centre of gravity that you can
do some research into finding the aforementiuoned system as i am sure that lamborghini aren't the only ones that do it and you may have a mechanical engineering friend that may be able to build some kind of pneumatic system that attaches to your front adjustables
rod
https://www.sau.com.au/forums/topic/280-suspension-quandries/#findComment-9849
Budget would be up to $3000, however could possibly go to $4000.
I believe I have two main options for lowering and raising the vehicle either being through hyrdaulic pumps or air bags. The bags seem to be the cheaper of the two options, and I've also been advised they would be the best as if a bag blows the cars suspsneison is still fully functional, where as if a pump goes, not only do you have oil all over the place, but the ride will be hard as. Another benefit of the bags is that they don't require a boot full of batteries to power. I'm not sure where I would be able to have these fitted though.
I'd certainly be more interested in having the car lower with a full kit from Whiteline and bags installed on all 4 points to raise and lower the entire vehicle for obstacle navigation than to have to raise the ride height at all times.
Has anyone attempted such on their Sky ? or any other vehicle for that matter.
https://www.sau.com.au/forums/topic/280-suspension-quandries/#findComment-9850
Jimbo,
I got the handling Pack ( Sway bars, suspension bushes,adj s=castor and camber etc). I made the mistake of letting them install the kit. I'll tell you all the details when we meet up on the next cruise. Get your mechanic U trust 2 install Ur suspension and get a wheel alignment.
I wanted my car 2 handle like Schumachers Ferrarri, with softer rear settings for 0 -400 m launches. The front is extra firm with a triangular strut brace for added torsional rigidity.
It took me around 6 months of homework to decide on a package and setup.
Best of luck with Ur choice... and remenber...ask around
https://www.sau.com.au/forums/topic/280-suspension-quandries/#findComment-9853
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
    • Yup but for me its the HR ! Cut my teeth on the old holden 6s in the day ! And here's me thinking in the day it was also the 300ZX and the Mitsubishi GT3000 ! All, as well had good lines, but always seemed to need finishing off, style wise.
