i have one 400r kit for a r33
give to me as payment for a part that i sold. so its for sale
kit consists of
front
side
rear bar
front grill
and eylids
unpainted but ready to go
same as one below
you have to paint it which mean probably 600
dont really want to sepparate
asking 900
pete 0409226626 sydney
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/
  • Replies 60
fatz,
i might be keen if you can hold off for a little while...
i am paying insurance this month as well as getting a S-AFC, so i'd be hella keen in a month or two.
if not, then thats cool.
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/#findComment-49812
kit is new *** sik as lol
Gerds - im talking to a few people to find out how much it would be to paint tha bastard... looks like being 600 at a place on paramata road. that make 1500 and *** me for 500 ill fit the bastard cant be that hard couple of self tappers and a few hours(never done it so thats a bit tounge in cheek).
prank- if its still there when your ready no dramas
jimbo- fresh out of the molds
front bar
side skirts
rear bar
front grill
and eylids
for 300 more can get a gtr wing if you like but i doubt it
pete
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/#findComment-50249
place on para cant remeber its name but when i worked for big boyz toys they sent a few car there so i know the guy now.
he did a repair and paint blue metalic flake front and side skirts for 600 and that was tops so im sure standard paint would be cheaper
can and will find out the name on the weekend but its opposit bp and where the old hooters was
prank- yup they r **** hot fill the guards nicely ill take a photo in a minute and post it up. stake knifes r dodgy but there yours from a drunken night at blackstump stole a few for kicks
body kit pphotos will be up tommorow night depending of drunkeness
r
pete
https://www.sau.com.au/forums/topic/2800-400-r-bodykit/#findComment-50773
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
