38mm Jjr Ext. Gate And To4e Garrett
Not impossible but unlikely, I changed it at the same time I changed the fan. Aftermarket of course, Nissan wanted more than a R34 Nur for a genuine one
Good price bro, list it up on Facebook Market Place. You'll have to deal with heaps of dumb cnuts but it will sell much quicker. -
Lazy clutch hub not engaging properly? Even on a 35 degree day with the A/C on, mine doesn't overheat. Just the coolant hoses behind the starter decided to weep and put the car off the road for 6 months instead llolol -
I figured it’d be a pain to install but I’ll give them a call in the morning to get confirmation. Thanks for the response and advice!
I'm running the Gtech fan in the Stagea, it overheats just the same as it used to with a stock fan Using an n1 water pump on a road car was a bad idea but I've never got around to pulling everything apart and changing it *edit* specifically, if it is idling on a hot day, it keeps getting hotter until I chicken out and turn it off. If I keep the revs above 2000 it cools down again
