yeah my car had PFC, 11.8:1 AFR tune at heathcote drags was running 105mph at dead on 1 bar, swapped the dump/front in the pits went back out and was doing 103mph same AFR and boost...so i did infact go backwards..but due to it being later in the day when it was warmer we can take the temperature into consideration
  • Replies 46
Posted Images
when i first bought my GTR it came with an Apexi Stainless front Y-pipe, standard cat, and 3.5 inch cat back exhaust (rusted) and with holes in it.
i replaced the cat back exhaust with a 3in stainless cat back and 3.5inch muffler. noticed no difference at all.
exhaust blokes told me the only thing holding me back is the standard cat, they explained it this way,
"think of a garden hose spraying water, and what happens when you put a kink or pinch the hose together?"
because the standard cat wasnt the same diameter as the rest of the exhaust the front pipe and cat back were pretty much useless, they had probably a little gain over standard diameter exhaust and obviously changed the sound but flow wasnt at its best.
then changed the cat to a 3inch high flow metal cat. noticed a big difference in spool up as soon as i left the exhaust workshop.
i've since got dump pipes when my turbo's were changed, that little bit wider pipe has made no difference, but i thought i may as well, on a GTR you're only talking 15cm of dump pipe anyways.
if you want the full benefit of a larger exhaust? "do it properly, get a full turbo back exhaust"
that way there are no restrictions.
far out forgot to say i yeah i got a 3 inch exhaust catback.. he said its ceramic.. and that it'll break if i boost it too much..he sed it can't handle more boost.. so i was wondering what would happen if i do boost it and leave the current exhaust? also my mufflers kicked in a bit. does this ruin performance? lol. Thanks for the replies
I am pretty sure he is referring to the type of components inside your cat. Cat's are measured in CPSI which means cells per square inch, the lower the number the higher the flow (I think anyways), so first you want to make sure you get a high flow cat to get the exhaust gases out as quick as possible. Now the internals of the cat or substrate can be made from ceramic or metal with the metal ones more resistant to thermal and physical shock and can withstand extreme temperatures. Having said that plenty of high flow cats have ceramic substrates - have a look at justjap.com - ceramic high flow for $179 whereas metal substrates are closer to $400.
Sooooo, get a highflow cat, for a standard turbo running 11psi don't think you really need a metal substrate cat, save the money and use it to get yourself a 3inch dump/front pipe.
Now having said all this, I am running a stock exhuast on my R33 GTST and the above is what I've learnt as I research a 3" turbo back setup for my own car.
I still don't know whether an integrate dump/front pipe is better than separate components or if a bellmouth is better and lastly if a dual pipe front pipe is better than the single set up.
Hope some of the above helps.
Edited by bradmax
i think he meant my catback was too thin, and if i boost my turbo .. my 3"catback won't be able to handle it and it'll break my exhaust.. lets say if it does break.. would it just be my exhaust? or will it damage other parts aswell.. cos what im thinking is i may aswell keep my exhaust til it does break (if it does) rather than buying a new one.. and i dont have a fmic.. do you guys think i need it for 11psi?
mate stop worrying about "breaking your exhaust"(WTF does that even mean!?) and worry about "breaking your turbo". search the forum and find what mods you need BEFORE you go winding up the boost. your exhaust will not break. also, if your muffler is f**ked, thats somthing that needs replacing rite away. modifing your car isnt as easy as simply adding more boost. adam
Thanks for replies.
do you guys reckon that it'll be safe to boost to 11 psi on my gtst? i've got a catback exhaust (i will be putting down/front pipes) and a pod filter installed..
And an aftermarket heavy duty clutch. would that be enough or will i need a front mount?? As its only 11psi most ppl are saying i dont need a Fmic...
You don't need an FMIC. The SMIC does a good enough job for your application... As far as exhaust breaking because it's ceramic... no. You must have misunderstood your mechanic, what he is saying is that your exhaust turbine wheel is ceramic and anything more than about 12psi and you risk smashing your turbo...
Get the front/dump to complete your exhaust, whack your pod and heatshield on get the car breathing right and 11psi will be nice...
Good luck.
i would get a fmic before summer comes. but it also comes down to how you drive. if you drive it like a nanna then even in summer the stock cooler will be fine. if you fang it a fair bit then you will need a fmic. the stock cooler suffers from heatsoak pretty badly which means you aren't seeing as much of a gain from running higher boost as someone with a fmic.
Just to clarify some things that you obviously misunderstood or yourmechanic didn't explain.
1.) The ceramic that will break that he is talking about is the exhaust "WHEEL" of the turbo (the back of the turbo)
2.) your exhaust is too thin?? he is talking about the fact that you still have the stock Dump and front pipes (and probably cat).
3.) the reason stock turbo's break is usually due to heat and shaft speed (which causes the heat). If you have the stock dump pipe, it gets a ALOT hotter there when boosted over stock because it does not flow very well and causes a restriction. a restriction in front of hot exhaust gasses causes the area to heat up more.. and so the chances of breaking your "ceramic" exhaust "wheel" is higher.
4.) do you need aftermarket dump/from pipes? no.. but it will free up exhaust flow so it is a support mod for increasing the boost.
5.) do you need an aftermarket intercooler? no. the stock one will be good enough for the stock turbo and 12 psi for usual street duties (95% of your use of the car no doubt).. but if you intent to drag or circuit your car frequently, then an upgrade would be good as you will be on the throttle for longer periods and the stock cooler would get heatsoak.
Your 3 inch cat back exhaust is fine.
Your cat converter (probably a compliance item) is uaully really shit so look in to replacing that if/when you do the front pipes.
Pod filter is not required.. get a K&N panel for the stock air box instead.
what you'e going to find when you go to 11 or 12 psi or actually probably anything over 10psi is that you will get R&R problems (which will feel like a boost cut)
usually around 4500rpm...
so you've got other things to worry about..
R&R = Rich and Retard (kinda like Paris Hilton but with less skank)
the standard R33 ECU will modify the air:fuel mixture by making it run rich and retard the timing when it senses something outside it's expected parameters.
quick lesson.
air goes in through the air filter, goes past the AFM (air Flow Meter) which sends a message to the ECU saying "Hey bro.. there is 12 air habibs coming your way"
ECU goes "No worries bro.. I'll douse them with 2 bits of fuel and burn the f**kers"
the air (habibs) go through the turbo and get all hot and angry like a bunch of lebs that just did 14 sets of bicep curls in a power cage, then through the intercooler to coll off a little, then in to the motor where they think they are entering a hektik nightclub only to be doused in fuel and burnt and spat out the back of the turbo and out the exhaust.
so..
The AFM (lets say is a Kiwi bouncer.. you know.. tough, but can't really count much) can only measure up to a certain number or air.
when you use a boost controller (lets say a hot chick bro), and you turn it up (reduce the length of her skirt and shrink the top), more air gets forced in to the engine (lots of habibs get calls from their cousins and they call go to this place and try to get in).
The AFM can only count so much and realises that there is too much air going in so sends a message to the ECU saying "Bro.. I only counted 15 habibs but I think that another 10 of their cousins snuck in... I'm not sure hey.. I didn't learn to count that many"
ECU goes "f**k you're a stupid coconut c*nt... now I have to deal with these habibs"
So as the habibs make their way through the turbo and intercooler (no doubt stealing stuff along the way), and in to the motor, the ecu douses them with heaps of fuel and makes all the habibs really wet with fuel.. this means that when they are burnt off, they don't burn well and so come out as darker smoke.
Because of his bad mixture (too many habibs in the one club), the ECU also retards the timing (closes the bar for a while) meaning that everything works really badly... all to protect the motor (hektik club) until the AFM (bouncer) gets his shit together and counts properly.
all this means that your car will jerk as if it's hitting some sort of cut or has a fault..
but it's just your car's way of telling you there are too many habibs.
How do you fix this?
Cheapest = A signal bender of some sort (Apexi SAFC is probably the cheapest)
this is a device which teaches the AFM how to lie to the ECU.
You turn up the boost, and 30 habibs arrive and run through the entry door..
AFM goes to the ECU "Hey bro.. I've just sent through 18 business men hey.."
Ecu goes "thanks mate. I'll give them the fuel needed"
this means that you get a leaner mixture and it all makes more power.
a better choice? after market computer.. there are lots to chose from.. do a search.
the after market computer (replacement for the ECU) is fully programmable and so can adjust timing too.. it can also mean that the coconut at the door doesn't have to lie, but instead, it is send on a few special classes and is taught how to count..
Hope this helps.
sorry to hijack this fourm but.. would a stock r33 bashed out cat make a diffrence? because i bashed out my cat and got a tune...would it be worthless if i put my 3inch catco cat back on?
i drove around for two whole years with my car boosted to 12 psi. turbo absolutely would not make anymore power.
i never tracked/raced however.
but i did used to drive it hard around town. i know for a fact the car was used for track purposes before i took ownership too. maybe i was just lucky.
quick lesson.
so..
Hope this helps.
Best explanation ive ever heard.
Thanks for replies.
You don't need a front mount at this stage. If you are worried about it get an R34 GTT smic
which will bolt straight in with no changes to piping and will be good for at least 200AWKW.
    • who can tell me what this is and why my car talks to me? i think it's hilarious. it's on my r34 right above the drivers-side storage compartment. the characters under the wrench say "inspection". every 10 or 20 startups, a voice starts talking in japanese from some speaker in this area below the dashboard. it says a few sentences then shuts off. different from the ETC card reader voice that happens every time i start the car. I've never found the speaker, i've never been able to catch the voice and translate what it says, and i've never found a forum thread that tells me how to reset the warnings. the holes in between the symbols are NOT buttons you can press to reset the warnings. anyone else have this? has the demon lord from Hereditary infected my car?!
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I tried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4   I did the other 5 in less time than I fluffed around with the first one. With the first couple I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the outer casings. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I over cut one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
