Enkei Wheels have released the lightweight GTC01 in the R35 GTR fitment
fitment:
front: 20x9.5 +38
rear : 20x10.5 +18
Enkei have long been a leader in the performance wheel industry. The wheels have been manufactured using Enkei's Enkei’s Most Advanced Technology (MAT) and Dura Flow forming.
With stems leading back to development of Formula 1 wheels for none other than Mclaren, the use of Enkei wheels by RE-Amemiya in the D1 category, as well as being used by MCR for their GTR demo car as illustrated in the pictures below
Special note which will please GTR owners is these wheels also feature the anti slip surface inside the rim, a common problem being faced by those trying to replace the OEM wheels.
PRICE: PM FOR SAU PRICING !!! LIMITED STOCK
(Only available in the Hyper Silver)
(FYI THE OEM BRIDGESTONE TYRES ARE IN STOCK NOW,
THE DUNLOPS ARE PREORDER WITH UNBEATABLE PRICES ON BOTH!!)
For those that want another option for track and availability to Proper semi slicks or want to experiment.
We have the 18x10 Enkei GTC01 +22 offset coming from Japan in about 3 weeks time.
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
