Hi guys,
Over the weekend I had some drama's ending in non exsistant ECU codes before it decided Code 21.
Found the culprit....drum roll.....
Ignitor pack wires are eletrical taped together, with no solder
(Don't buy off eBay)
Now before I solder it, my questions are:
* Should I cut the wires and solder in an R32 ignitor pack (incase it dies in the future, easier to find a replacement)?
* Any specific brand of coils to replace while I'm at it? I'm told most brands die quickly, havent heard about Splitfires?? If the difference between a $300 set and a $700 set is still short lived, I'll just be le-cheapo's.
* Which specific coil? I've attached a pic of my current coils, I dunno if theyre early or late model, or what one would classify as "brown", so can anybody see and point me in the right direction as to which ones to buy, also consdering if I switch to R32 ??
Thanks a million guys.
-Nic
Thanks SirRace.
I'm gonna replace the works, it all looks pretty nasty.
TWO QUESTIONS:
Does the R32 Ignitor box have vertical or horizontal pin orientation?
Where does the Ignitor get power from?
I want to replace the harness's, both sides, I didnt look too hard, but the lines into the box join the other lines that run back into the firewall to the ECU ???
Can't work out where that harness goes and Nissan FAST just confused me even more?
My wiring is all really stiff and burn out. Cylinder one has copped the worst, alot of burn marks visible from the valley.
Time to replace both harnesses, the ignitor box, Splitfire coils and new spark plugs. Then she'll haul ass again.
Cheers in advance fella's.
The R32 ignitor and A31 ignitor are identical (both in pin arrangement and horizontal/vertical orientation) it is just the plastic casing of the plugs that is different.
The ignitor wires go to the ECU, so I don't know how you'd go about fixing damaged wires there unless you replaced the complete engine loom (or stripped parts of your loom back and soldered on some new wiring).
I'd consider converting to external coils with built in ignitors and running regular ignition leads. This way keeps all of your wiring loom and coils away from the engine heat.
Just picked up another loom, pack and coil wiring loom from wreckers. I heard the ECU loom end of the wiring go crunch when I pulled it, it might be the cause, but the pack is definately cooked, and the coil loom. I'll have a crack and stripping back and resoldering the ECU end of the loom, but I'll still be replacing everything from the pack to the spark plugs.
Cheers fella's.
mick from ovaboost performance suggested i ran Hyundai Sonata coils in my ceff, so i got them through coventrys, from what i remember they were $200 all up.. mounted them on the fire wall and ran plug leads into the head and onto the spark plugs, he was telling me he ran 1mm plug gap with around 20pound of boost and the spark wasnt affected at all. I havent had any trouble with them and ive done around 5000kms using them, it also makes life alot easier testing a cylinder if its running shite.
V6 Hyundai Sonata coils are cool
lmao ^^^ awesome that it works but i wouldnt want hyundai parts under my bonnet lol
ive seen people do the same setup with commodore coils and falcon ones no sure which models.
but 1mm and 20 psi def says the setup works well
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
    • I've got cash, it's the NA LOLS I'm after now Plus, I've had a few boosted cars, and it is soooo easy to turn a reliable car into a unreliable drivetrain eating money pit monster by just paging up and chasing more My power goal for the NC is to try for a reliable naturally aspirated 150kw or 200hp atw (I'm old, and the old naturally aspirated cherry of 100hp per litre is a goal that I would like to hit), no more is really needed for what I use the car for,  so a additional 5kw is what I'm chasing now,  that 5kw is about $3k away, I think....
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
