Removal & Replacement Of Heater Core Skyline - The Right Way, Without Removing The Dash At All
ok so did the bypass on the weekend which worked a treat until we can afford to do the full job...except now whenever i drive it once i turn the car off heaps of coolant comes out of the overflow bit in the coolant bottle. is this related to the bypass in any way? or do you know why it would be happening? everything else seems to be fine...
^ at a guess - the principle is the same. you'd just need to make sure the insides are the same as the write up i guess, have a look behind your glove box to see if it matches the OP's tutorial
kel*bel - could be, just keep an eye on your coolant levels to make sure your not loosing any, if it runs fine i wouldnt stress about it too much
looks like im gonna be trying this out on the gf's 31 soon, its been going for a while and finally started leaving big pools in the footwell
i've had a look and it looks pretty similar to what you described, will report back with the findings
Hay mate just did the today using you tutorial saved me so much time! Anyway i would like to know what did all you guys do to get all the coolant out of your carpet and car? did you get it detailed or pull the carpet up and clean it? was just curious as to how everyone went about it?
you could get it detailed - might as well get your whole car done as well to make it worth while. or hire a wet/dry vac and do it yourself
dont know how well those these work but you could try moisture packs (you know the powder stuff in a container that is meant to suck up the moisture from carpets if you leave the lid off). once again, prob not good enough to completely get rid of it all but worth a shot i guess
Thanks Jason, you just saved me alot of money. Changed the heater core on my R34 25GT, all up it only cost me $200 - $50 for heater core and $150 for de-gas/re-gas and service the air con.
I phoned Nissan and they wanted $500+ for a new heater core - crazy. Much cheaper buying 2nd hand lol
Hope this heater core last I really dont want to have to do this again :D
  • 5 months later...
Awesome guide took me about 2 and 1/2 hours (that's not including a re-gas) the hardest part was those dickie screws on the plastic pipes.
I got quoted about $700-800 + parts for the job to be done (dash removal way) so about $980ish
This job has costed me so far
$180 for brand new heater core
$40 for De-gas
$130 for Re-Gas (when done)
Total - $350
I'm very interested to know if anyone has achieved this on an r32. I've got a 4 door gtst which the heater core needs replacing and I'd really not spend the $1000 in labour to remove the entire dashboard. I find it hard to believe the dash has to be entirely removed in order to access the heating core.
  • 2 months later...
Thanks to your guide i saved atleast $500..did it myself and you just feel good after fixin it knowing that you did it in one day not like the mechanics..they freakin take time so they can charge more..i got quoted $800 for it :ermm:'
$280 for the heater core..brand new
$40 for the regas
$100 for the regas
Thanks mate top job!
<quote>
Step eight: So now that you have the upper and lower plastic pipes removed from your firewall, you will now be able to remove the heater core element from the heater box. BUT FIRST...There is a plastic clip running across the element holding the element it in place, you can do one of two things here: snap it off in frustration or take your time and try prying it off slowly. I cracked the shits and just snapped it off – you don't need it anyway, all it does is hold the element in place during manufacture, that's what I think anyway! The aluminium heater core element will happily slide out of the heater box and you will be holding it in your hands.
</quote>
There is actually one small screw on this plastic bit holding it in place. Its on the top side of the plastic bit on the right hand side.
  • 3 weeks later...
Wow what a time and cost saver. I read the instructions about ten times thinking that it couldn't be that easy...... But it was.! Took me about an hour and a half Thankyou very much!
  • 4 weeks later...
$40 for De-gas
Total - $350
Rob where did you purchase a new heater core from? I'm after a R33 S2 one myself.
Yeah I'm dealing with it as well, though I'm taking a slightly different approach. I've still have the AC connected, and have managed to get the heater core out. It took more work obviously, but since I have more time than $$ at the moment, it was worth it for me. I had to gut the inside of the car to get the carpet out anyway, so have taken the whole dash apart and took the heater box out. I see on the heather core where there is some white corrosion stuff, or calcification, so I imagine that's where it was leaking. Not sure if it can be fixed, or if it's even worth fixing $$ wise.
Still hoping brat81/rob will reply back as to where he got his new core for $180 from.
  • 6 months later...
Great write up. I've got a problem with water bubbling sounds in the dash, but there are no leaks.The bubbling sound comes on when taking off from being stationary and goes away after a few secs, my mechanic said its most likely the heater core. Would this procedure fix the problem?
ETA The car is a r34 gt-t sedan
Edited by skizza r34gtt
This method is the absolute bomb. :worship:
It took me less than 2 hours to do this job. The most inconvenient part is taking the car to get degassed and then regassed.
Saved bucket loads of cash that are better spent on say a bigger turbo or a power fc. lol
Trickiest part was definitely screwing the plastic pipes back on the heater core while upside down under the dash LOL Those little screws are a pain. :rant: Highly recommend a strong magnetised screwdriver for that job. :-D
  • 2 months later...
I think my heater core is gone... I get the smell of hot coolant when i turn my heater on and constantly getting steam coming up on the inside of my windshield.
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
