Hi fellas,
I just bought a set of original 18" Nismo LMGT4 black rims. Although they look ok without the centre caps - I prefer them. Does anyone have a set they want to sell or know of a place that sells them. I don't mind something that is after market or even just plain black just to cover up the centre gaps.
I have tried places like J-Imports and they want like $350 for a set of 4 originals which is fair enough, but I just want something to cover up the centre caps and not fuss about looks now as long as they are in black.
Your help would be much appreciated.
PS: A few of my mates suggest just spraying the centre gap area black and it would blend in - anyone done this?
A few things:
Be careful because on some of the Volk rims the flat caps (the ones in the first photo) don't clear the wheel bearing cap on some rims.
It is common to lose the damn things when you kerb hop at the track.
You can get them from Greenline/Nengun etc cheaper.
It may just be easier to neaten up the bearing cap eg paint/anodise it & use a shiney split pin.
A few things:
Hey mate,
Thanks for your reply.
I kinda think having no caps looks kinda tough. What do you mean by: "It may just be easier to neaten up the bearing cap eg paint/anodise it & use a shiney split pin?"
Do you have an example picture or something?
Thanks mate.
Cheers,
Kevin
I dunno, not like I have any idea what I am on about. :)
If you look at the photo you will see my pos. Bearing cover is missing paint, hub is a lovely shade of iron oxide & the open ended nuts are bleeding red where they exposed metal on the studs & then got wet.
So yeah, tough in a adandoned shopping trolley kind of way.
You can remove the bearing cap & paint or anodise that. Then use a shiney new split pin. Also the hub centre can be cleaned up & painted a bit too.
Or just get some caps & stay away from the kerbs & carparks.
Edited by djr81
I dunno, not like I have any idea what I am on about. >_<
Ha ha ha.... I get ya now bro... :)
I think I will just spray it black and leave it... although I would prefer to have the caps - they're just so blood expensive.
You got any idea where I can get some cheap non-branded caps from?
Cheers,
Kevin
if you have any luck with original ones at a non ridiculous price let me know please, I'm in need of 2 bronze flat style caps.
cheers, tim
Yeah will do - still frantically looking for mine. ;)
Guys try Nengun....or Powereplay imports but they can be expensive.
Im pretty sure nengun have different types such as "Rays" or "Nismo"
Thanks mate... yeah, they would but would be expensive... I just cannot just paying like $400 for 4 centre caps.
This is what your after.....
http://www.nengun.com/rays-engineering/lmgt4-center-caps
Does anyone have a picture of the 'high type' caps? I've got a feeling the flat ones look better!
This is spot on what I am after. Thanks mate. $35 each is not that bad...this I can definitely afford.
What do you think looks nicer - those flat ones or the badgey looking ones?
Flush ones do look better but they may not fit. You need to check.
Yeah, that's exactly what I am worried about...I'm not going to pay like $200 for a set of centre caps only to find the damn things don't fit. Can't really ask the seller for a refund just because I wasn't sure in the first place.
I do like the bold ones, but don't know if it would stand out too much.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
