intake air temps would be worth talking about rather then the "BRAND" but im guessing many of you dont check that.. with back to back testing the garret cores seem to word really really well over the cheaper coolers look into airtake temps
True, but im sure people are going to go buy an intercooler, find that the intake temps arent that much better, then buy another one.
Nor do many people have access to each individual FMIC to do the test.
And as far as i have seen on this forum, the people that do pre and post intercooler temp readings are far and few between
if its stock boost, then keep the standard intercooler
the issue isn't ambient temperature but how the car is driven and loaded up
if you go for a trash run and load it up flat out the standard core will become heatsoaked
that is, its full of heat and any air coming through it, won't experience a good temperature drop (or worse than before)
and because its a smaller core, in the side of the car it will take considerably longer for the heat to be extracted
so as you continue to load the ass out of it, the intake charge will be mega hot and the intercooler effieicny will be very poor
if you did this with a larger front mounted core the core would remain cold on the outlet side at all times
as the core is larger and its able to extract the heat easier and there is way more surface area and its directly in front
if its stock boost it would be fine
next time you go for a trash run
stop the car
get out
feel the intercooler
one side should be hot hot hot
one side should be cold cold cold
if its efficient it will be like that
if its inefficient, ie heatsoaked, both will be hot hot hot
Mine got overwhelming heat soak with an R34 SMIC. They dont get enough airflow for any real periods of hard driving. But all the comments are correct.
It will be fine at stock boost levels. A gauge is only an investment cosmetically untill you up the boost ;) I only ever splashed out on mine because i thought i was getting a lot of boost creep. And i was.. so it was an investment on my part (turbo wise :( )
If you start track racing or drags, you will find the SMIC in-effective.
