  • Replies 49
sooooo do we need just one more person for this to go ahead?
Pretty sure we're good to go with 4 people. Jap rails are getting sent down in the next couple of days, and ccubed are organising individual invoices. Darrinspencer will have more details shortly... :P Hanging out to have a complete car again!
  • 2 years later...
Also, are they still available? (ie: another run?)
I do own a pair....That Darrinspencer currently has in his possesion...who i keep meaning to call( My apologies!!) that I will be selling due to the fact i know longer have a C34.
No stress mate, we are always too busy
Sorry to kill your possible sale
After waiting 13 months to get these made, the quality was shit.
They were suppose to take 6-8 weeks to get made!
Have a look when this thread originally started!!!
The guy was well capiable, recently making all the carbon work for Handbrake's mega R35 GTR build, but managed to totally give us a crap job and charge us for poor service.
I have had to fully bog the entire length to get them flat
Will be in primer either this weekend or next
They are not good enough to just paint and fit.
Any of you guys tried to use the existing plates with some fibreglass mods to bolt them down and clean them up in the sections where the racks went through them?
Ive got a spare pair of rails i'm thinking of trying this with. Should cost much (like $20 in fibreglass and resin). I'm just assuming there is a reason it hasn't been tried yet
I did have a original plan of fully covering the entire roof strip in 1 or 2 layers of fibreglass, then bog and sand and paint.
The problem with the roof strips they are covered in a rubber/plastic coat over s/steel metal.
Too hard to remove the coating, plus the front end is approx 4-5cm long of solid plastic, not metal.
Still worth a try.
Pics of the fibreglass ones we bought
This was last weekend. Now both sanded and getting undercoated this weekend
Edited by darrinspencer
Still worth a try.
this is what u should of done before u painted urs Darrin
  • 2 months later...
Does anyone have a picture of how the roof is bonded to the chassis?
I'm having my Stag re-sprayed in a few months time & the paint shop says it's dinted to hell & may be better to replace entire roof. I would love to find a dual sunroof car & convert mine.
3 quotes I've had so far range from $6600 to $9000 for full job including fitting this kit (supplied by me) http://www.freeway-dolphin.co.jp/aeroform/stagea/nissan_stagea_c34-wh.htm
Thanks.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
