Does anyone have a picture of how the roof is bonded to the chassis?
I'm having my Stag re-sprayed in a few months time & the paint shop says it's dinted to hell & may be better to replace entire roof. I would love to find a dual sunroof car & convert mine.
3 quotes I've had so far range from $6600 to $9000 for full job including fitting this kit (supplied by me) http://www.freeway-dolphin.co.jp/aeroform/stagea/nissan_stagea_c34-wh.htm
Thanks.
The roof skin is joined/welded under the roof rails, that is why they are there
You will have to remove the front winscreen as well to fit/replace the skin. Approx 6-8 hours to go replace skin and remove the new skin from roof cut
I would really find a better panel shop to fix your existing roof
I helped do my 2004 lancer roof recently. Done in approx 4-5 hours
Do the quotes to repaint the car include removing and re fitting the side rear quater glass and tail gate glass?
It cost me approx $500 to get someone to cut out side glass and tail gate glass and then come back to refit after painting. I left the front windscreen in.
You will most likly need to replace the front screen moulding and the hatch screen moulding plus they ahve a hidden retainer as well. Allow another $400-500 for these
Make sure if the side rear quater galss comes out they do not cut the rubber as it bonded to the glass. It can not be replaced and is very easy to damage. other wither new quater glass is $850 a side
As to respray costs...find out what brand of paint as good stuff costs alot more
You can spend $150 on 4L of clear or like me I spent over $500 on clear
My total paint materail cost was over $2500 alone, but that was inside and out and full kit and engine bay. Colour was $170L....I used 8L.
Is the body kit a copy or genuine? How good is the fitmen going to be. Have the panel shops seen the quailty
I bought a doggy copy rear bar and side skirts and spent 50-60 hours to get them to fit
Just make sure you know all your cost up front before you start the job....other wise you might be up for a few extar grand.
Hope that helps
  • Replies 49
  • 1 month later...
  • 11 months later...
Forget it mate. They all turned out like shit. Many hrs spent bogging and sanding to get them to look good and they are still wavey. It just about works out cheaper to fill the gap in steel and repaint the car.
hahaha considering what the above link would cost to get them sent over and even then would they be a perfect fit and therefore value for money? who knows. At least yours are close and cheaper :-D
    • I dunno. I just go off what I know works. On RB20, the idle switch meant something to the ECU and the potentiometer was ignored. In Nistune, with the switch unplugged, you could bridge the terminals in the loom connector and see IDLE come on and off. Not so by moving the pot. The R32 RB20 ECU and the 26 ECU both look like this. Sure there is the "throttle sensor" (pot) on pin 38, and also sure, the idle switch is also directly wired to the TCU, whereas the pot is only directly conected to the ECU. But I am sure that the throttle position from the pot is passed to the TCU across the data bus on pins 21, 22 & 31. Maybe the ECU likes to know throttle position, but it sure as hell doesn't use it to determine the idle condition. Meanwhile, on the later engines, like the 33 25DET and my Neo, you remove the TPS and move the pot to-from the 0.45V position, and IDLE comes and goes in Nistune. No throttle switch on the ECU diagram. Just the pot.
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
