99 YAMAHA WAVERUNNER 130HP
RECENT REBUILD SO GOOD FOR AT LEAST ANOTHER 10 YEARS IF MAINTAINED PROPERELY
VERY CLEAN ENGINE BAY ALWAYS FLUSHED
R N D RIDEPLATE
JETSPORT SEAT COVER
$2000 TRAILER SEA TRAIL DELUXE
FOR MORE INFO PLEASE TXT 0449655166
$4000 VERY CHEAP
Edited by SUN32RISE
https://www.sau.com.au/forums/topic/280258-yamaha-waverunner/
