with 250kw at the wheels, mine must be 400hp awd :devil:;)
now dont talk costs :)
you'll need more than 3k to smash that xr8,
highflowed turo, garret spec, $2500
ecu remap/piggyback, $1000-$1500
fmic, dump pipe, air induction, $1000
and the list goes on....
More like 430hp... nice.
Those who don't have it want it.
Those that have it want more.
Those that have more are still not satisfied.
:) such the wallet hating addiction we seem to have...
did you use 30% drivetrain loss?? thats not necessarily true. generally the drivetrain costs power eg, 50kw, but it would be around 50kw no matter how much power you have. does that make sense?? there are some discussions about this ;) like a supercharger might cost 40kw to turn it, but the gains of forced induction gain more power than its using.......
did you use 30% drivetrain loss?? thats not necessarily true. generally the drivetrain costs power eg, 50kw, but it would be around 50kw no matter how much power you have. does that make sense?? there are some discussions about this :P like a supercharger might cost 40kw to turn it, but the gains of forced induction gain more power than its using.......
I know you were talking generally, but drivetrain loss in a stagea is more like ~85kw. Based on s2 having supposedly 206kw and ~120awkw. Somehow the M35 250t with a very similar drivetrain still has 206kw but manages 135+ awkw. go figure.
Most other cars seem to have around 50-60kw drivetrain loss, so that makes sense. If you remove the front tailshaft in the stagea, the difference on a dyno is ~20kw compared to awd so that tells me that the awd "costs" about 20kw. However, the extra traction more than makes up for this on the road. Those who have been to the drags and tried a run with awd and then rwd (but in a awd stagea - so same weight) claim that the awd is quicker, despite the extra drivetrain losses.
For what its worth, factory rwd is a different story since we're then talking about a ~200kg weight difference.
yeah its pretty damn high, but what im explaining to others (i used 50kw as an example) that no matter how much power you have, the drivetrain will always take 85kw (for an M35 auto) not 30% which may end up being a bigger figure. i have more experience with silvias, AUDM S15s have around 40kw drivetrain loss, a little more efficient than their S13 bretheren at almost 50kw. but thats technology advancing. better still my honda lost 30kw which i think was pretty good!
yup i agree. I owned 2 s13's, one of them turbo. Very quick car (the turbo)....but a little slippery in the wet.
LOL.. Nah, I used SK's estimate of 70kw for the S2 regarding drivetrain loss which makes more sense to me than a percentage as why would the drivetrain sap more power from the engine the more powerful the engine is?
I figure it takes me X amount of energy to lift a chair. If I went nuts in the gym and grew 50% stronger, would it require more energy to lift the same chair? No, it would require the same energy, but I would have much more left over due to the strength increase (which is why it would feel easier to lift it).
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
