Wondering if someone out there can help me out with a link or even better answer some questions i have of this car.
Looking at some pics of the interior i can see a Motec LCD Dash Logger.
Now this gets me thinking about the claims that this car uses a Power Fc & AFMs, i also noticed it has an AVC-R on its dash.
So anyone know if you can use the Motec LCD Dash Logger with any ECU, or for that matter other dash loggers like those by PI, Magneti Marelli, Stack etc etc?
https://www.sau.com.au/forums/topic/28028-apexi-v-max/
Yeh those were the piccies i was looking at.
Id love to know if those dash loggers can be used with a range of ECUs. I have seen Stack clusters being used on cars in Japan with HKS Fcon V Pro ECU, but everytime i have seen the Motec dash logger it has been with a motec ECU.
Then again i recall Glen Seton and Larry Perkins use to use Autronic with PI dashes...still id like ot hear from anyone with experience with Motec and Apexi, whether the two systems can be used with one another... or is Apexi claiming accolades that perhaps belong to Motec?
https://www.sau.com.au/forums/topic/28028-apexi-v-max/#findComment-584212
Interesting, i know Keir Wilsons GTR runs both a power FC and a M800 motec unsure of its advantage but there must be one.
You would think the motec dash would only be used with the motec computer but maybe there is just a datalogger that uses the dash to display certain info for downloading.
https://www.sau.com.au/forums/topic/28028-apexi-v-max/#findComment-584235
Hi guys, you can pretty much use any data logger and/or dash board with any brand of ECU. We even have data logging on cars with carbies.
Generally speaking they have multiple analogue and digital inputs and you can plug any type of sensor into any input and log the data stream. The dash board merely interprets and displays selected data streams.
It is obviously easier to plug a Motec ECU into a Motec Dashboard/data logger using a Motec wiring harness. But we have Pi systems with Motec ECU's, Motec dashes with Autronic ECU's. We even have a Pi data logger with a Cdash and a Power FC.
Moving on to VMax, I can absolutely confirm it has a Power FC and uses 2 X Q45 (90 mm ) AFM's. It used that set up to run an 8.75 on slicks.
Hope that helps
https://www.sau.com.au/forums/topic/28028-apexi-v-max/#findComment-584732
Thanks for confirmong that. Spent most of last night reading thru old Racecar Engineering mags and picked up plenty about data acquisition.
Once i realised it was possible and failry common, one thing still didnt make sense. You have a car which is being used for drag racing where you have gone to stupid lengths to reduce weight.
Then as Sydneykid mentioned its much easier to use the data logger with a Motec ecu, but is is also several kg lighter. You can use the one wiring harness, reduce the amount of sensors, avoiding duplication... but i suppose its an Apexi demo car and it needed to use Apexi gear to showcase it.
So now only have to ask Santa for a PI or Motec dash for Xmas.
https://www.sau.com.au/forums/topic/28028-apexi-v-max/#findComment-585024
Im not looking at buying any really...only dreaming. That said i like understanding the theory behind some of this stuff, it would be great one day to get some practical experience.
I HAVE to stop spending money on my car, its going to be up for sale as soon as i find a sponsor to work OS.
https://www.sau.com.au/forums/topic/28028-apexi-v-max/#findComment-585890
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
    • Is the problem that we just disconnected the line, does it need to be plugged? I’d rather not buy another master cylinder
    • Clutch is same same. Tailshaft is not. Diff will drop in. Half-shafts will not mate up (5x1 on turbo, 3x2 on NA). There is also the strong possibility that your auto NA gets its speed signal from the sensor on the diff, not the gearbag, and that will leave you without a speedo. You can do all this, you just have to do a lot more than you thought.
