I am currently contesting a fine issued to my missus whilst she was driving my skyline
They defected the car for being 110db @4500 rpm which is ridiculous
Also by law you only have to rev the car to 3200rpm for a 6 cylinder vehicle which is on the national roads and transport commission website
my car was tested in braddon by roadside police and RTA also at 4000rpm and the car was 91db only a month back
The way they are conducting the tests is false and by law is wrong
I want to borrow a meter so that I can conduct a test properly and take my report to the head of police ACT and also to the RTA themselves as the way the roadside police and Rta are testing is wrong and not correct by law
I have one at work that I MAY be able to borrow. Let me know and i'll see what I can pull, may need to get you to test at my place or something one night after work.
However, just to correct you on some unfortunate facts since I've been through it before as well. The roadside tests (whilst never performed legally to the book) and all metered exhaust tests are to be conducted at 75% of ESMP (Engine Speed at Maximum Power). For an RB25 (I've only looked it up for my engine sorry), the rated RPM to measure it at is 4950rpm including stepping off the gas ubruptly to include that decel pop.
The dickson station has only ever measured at 3200 or 3400 (can't remember the exact one they did for me) and passed without issue, but the roadside, they only ever do 4100rpm+ etc because its the easiest way to get you off the road for driving an import. Which, technically is still legal since by the book it should be rated at 4950rpm.
http://www.ntc.gov.au/filemedia/Reports/Na...estSept2006.pdf
Still chasing up the doco I had on the ESMP of our engines, sorry.
Ok, found the PDF... http://epanote2.epa.vic.gov.au/EPA/Publica...;FILE/317.1.pdf - 2 and a bit meg in size, give it time to load.
RB20E - ESMP 5600 - 75% reading done at 4200rpm
RB25DE - ESMP 6400 - 75% reading done at 4800rpm
RB26DETT - ESMP 6800 - 75% reading done at 5100rpm
RB25DET - ESMP 6400 - 75% reading done at 4800rpm
Interestingly, cannot find RB20DET listed, which means it should be measured at 3200rpm the way I read it....
Edited by sfrizza
mine has the rb20de engine mine is a GTS not a GTS-T
I also downloaded the Test procedure guidelines in PDF format
which state
vehicles from 1970 to 2000
Default speed tests
Should not be higher than 90db @ the following RPM's
5 cylinders or below test @ 4000rpm
6 cylinders test @ 3200 rpm
8 cylinders test @ 3300 rpm
Above 8 cylinders @ 4300 rpm
and Rotary engines test @ 4500 rpm
That is the guideline set out by the NRTC I can send ya the PDF
Yes, but you are only reading what you want to read there... The guidelines specifically say that it is to be < 90db at 3/4 of ESMP UNLESS they don't know what that value is. In which case they are to do 6 cyls @ 3200rpm as a default setting.
All sorted ...
The Car goes in to the exhaust shop Mitchell for a new cat back section on Wednesday to hopefully Quieten the whole exhaust note a lot so the car isn't such a target
I will also keep my old cat back setup for track days as it is a nice exhaust
Was giving the Varex muffler option serious thought then was told by the RTA that they are infact illegal themselves so a complete catback overhaul should do the trick and shut it up
Want the car to be legal im over getting stupid fines and defects and not being able to enjoy the car for what it is ... I seriously don't have the time for the RTA/Police bullshit anymore
Somehow I keep having a feeling either my name or the cars that I drive are on some sort of police black list
Because twice now when the police have pulled up my missus driving my car they give her a lecture and keep asking her questions about me which I find to be an invasion of privacy ...
They also went right through the car searching everything when they stopped my missus I dunno what they were looking for but they didn't have my permission and I am the owner of the car , she was just the driver ...
Dunno if there is anything I can do about that by law ?
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
